koni front strut blown, should I replace with tokico?
Old Jul 24, 2004
Mark4124's Avatar
Mark4124 is an unknown quantity at this point
Well, I had my koni struts installed about 4 months ago at a local shop here in southern NH. There was some degree of trouble on the part of the mechanics as they had to cut the stock strut well beyond koni's recommendations in order to get the koni insert to hit bottom on the stock assembly. Those were installed in the winter. Granted I live in New Hampshire and our snow and potholes can kill anything. But nonetheless, I seem to be always having trouble with suspension stuff. The shop now tells me that my passenger side strut is blown. I also have noise coming from the front when I clock my wheel completely one way or the other. Seems almost as though they are not seated properly. But anyhow, given the pain in the *** it seems to be to deal with "inserts" as opposed to real struts, should I just switch over to tokico's which will not require my retaining the original strut? Btw, I have the Neuspeed Sport springs.
Old Jul 24, 2004
Titleist71's Avatar
i bet they put your strut assembly in 180 deg backwards. I had that happen when I got my car lowered and didn't figure it out until i took everything out again to do my shocks. Noticed some rubbing of the top plate and realized that they were not in properly. I also had some clicking/clanking sounds but they are gone now that its put together correctly.
Old Jul 24, 2004
Mark4124's Avatar
Interesting, that would explain the noise on turning, but I don't think that is why they told me the right front one was blown.
Old Jul 24, 2004
streetglower's Avatar
I would send you blown strut back to koni and have them replace it. They are under warranty. All you have to pay would be the shipping the old strut to them and the install fee for the new one. If I were you, I would talk to the shop, sounds like they messed up the install. Try finding a shop that has experience with the koni installs.
Old Jul 24, 2004
Zzyzx's Avatar
Autocross Junky
From hearing what the Shop had to do with your stock struts.... Sounds like you got the wrong Konis from the get go.... you probably got the 55mm struts when you should have gotten the 50mm struts. you have a 2001 or a 2002? If so then thats what happened.....
Old Jul 26, 2004
clownprince's Avatar
Ricerus Maximus
The way I see it, you can replace the Koni's because they are under warranty. Also since your front strut assembly is already cut open everything should be ready for a new koni to just be dropped in.
Old Jul 26, 2004
bad thing about konis warranty process is that I bought a blown set of konis from another member and sent them to koni for replacement and they are taking forever to send me new ones.
Old Jul 26, 2004
BlackFire's Avatar
BlackFire is an unknown quantity at this point
Well, I think you should ask koni to replace it under warranty.
I would not install a Tokico if you have koni in the other side.
Good Luck.
Old Jul 29, 2004
civic duty's Avatar
civic duty is an unknown quantity at this point
i have the exact same setup suspension with the same problem with the konis. I just got a new strut and dropped it in. Also my strut mounts were worn out you might have the same problem.
GH04si
Apr 15, 2015 08:13 PM
civiccowboy
Dec 7, 2001 09:20 AM
Daniel420
Dec 4, 2001 08:46 PM
andylao
Nov 4, 2001 01:19 PM
JeffSpeed21
Nov 3, 2001 10:32 AM
