blown shocks
Old Jul 16, 2004
gotrice's Avatar
gotrice will become famous soon enough
blown shocks
whats it like when you blow your shocks? can you still drive with your shocks blown and for how long?
Old Jul 16, 2004
TeLLy's Avatar
Yes, it's an Acura EL
I got so gradually used to my blown shocks that I didn't know when they were finally gone. But my buddy was driving behind me one day and told me when I went over a bump, my rear just kept bouncing up and down.
You can drive with blown shocks as long as you want, I don't think it'll wreck much else on the car...but safety-wise your handling is compromised if your shocks can't keep your wheels planted on the ground after a bump or dip. I would say I drove with blown rear shocks for about 8 months before I finally got my Hayames. My rears musta blown quick cause of my sub box in the back. It was to the point where the front was raised up cause the rear was sagging so bad. I have the stock rear shocks in my closet, I can move the rod up and down with just my hand....
Old Jul 16, 2004
Green Civic's Avatar
If you keep bouncing after the bump, you have blown shocks. It usually take one to two movements for the shock to settle back to normal after a bump. When the shock is blown, the fluids inside the shock cannot get the shock to level off, or has a harder time, which means the shock is blown. Most of the time the shock is leaking its fluid when it is blown.
Old Jul 16, 2004
HyaBoosta's Avatar
if whenever you hit a small bump you hear a loud thud in the font then your struts are blown
skeener51
Oct 1, 2015 05:56 PM
ken4444
Sep 30, 2015 07:37 PM
juicetayne
Sep 30, 2015 11:02 AM
raymondxcho
Sep 29, 2015 09:00 PM
Bruce2
Sep 27, 2015 08:45 PM
