B&G or GC
Old Jul 21, 2004
  #31
vietfob714's Avatar
vietfob714 is an unknown quantity at this point
will B&Gs go into an 03 sedan no problem or do i need extra stuff?
Old Jul 21, 2004
  #32
518's Avatar
518
518 is on a distinguished road
When I called their US Office in San Diego yesterday, they told me to reuse the oem parts and it should be the easiest intall in your life
Old Jul 21, 2004
  #33
SlammedBlueEM2's Avatar
All Eyes On Z
Nice. lol
It seems like these coilovers have gained some popularity lately. Probably thanks to Hayame.
Old Jul 21, 2004
  #34
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
the front strut won't fit the 03+ model.. the knuckle bolts are a different size haven't looked much into the issue though, so I don't know what the remedy is.
Old Jul 21, 2004
  #35
518's Avatar
518
Not a Civic pic, but is that the knuckle bolt you are talking about?
OR...
Is this the problem you are talking about? And what we need is just the bearing ring for the 01 Civic, anything else?
http://www.gametrax.net/b+g/
what an irony
Old Jul 21, 2004
  #36
518's Avatar
518
Civic 2001-2003 Strut Bearing, is it the number 9 on this illustration? Anything else we need from this illustration at all?
Thanks,
518
Old Jul 21, 2004
  #37
518's Avatar
518
pics from gametrax
I just noticed that the pictures for 2001 and 2002 and 2003 is different from my 2004. The spring isolator is MUCH bigger than the pictures on gametrax.net. The spring isolator is bigger in circumference than the strut mount (pic #10 on illustration).
If the pictures on gametrax.net is for the rear strut, then forget about what I said.
If the knuckle you are talking about is like the one pictured with a red strut, then I already have a remedy. Im running a smaller bolt to give me a -1.5 front camber.
Old Jul 21, 2004
  #38
All Eyes On Z
That's the front.
Strut
Anti sway bar
A-Arm
Knuckle & hub assembly
Old Jul 21, 2004
  #39
All Eyes On Z
Originally Posted by 518
what an irony
I would definintely spend the extra cash on B+Gs over the Hayame quality. At this point, Hayame has dropped the ball.
Old Jul 22, 2004
  #40
518's Avatar
518
Originally Posted by SlammedBlueEM2
That's the front.
Strut - 5
Anti sway bar - 13
A-Arm - 11
Knuckle - 3 & hub assembly
Did I labeled it correctly?
Did you say "that's the front" referring to the gametrax.net pictures? Because that the one I was asking about. It really looks different on 2004 front suspension.
I know the illustration is for the front.
Old Jul 22, 2004
  #41
All Eyes On Z
Yes, the gametrax one is the front.
How much do 01 Uppermounts run?
Labelled correctly. Hub assembly would be 2.
Old Jul 22, 2004
  #42
ironcow's Avatar
ironcow is on a distinguished road
i went to honda today and they said the upper mounts were 38 and the ring bearing was like 23
they are 15 $ cheaper online its crazy
Old Jul 22, 2004
  #43
518's Avatar
518
Okay, according to Mex there is also an issue on the knuckle where the OEM bolt wont fit. I wont have this problem since I am running a slightly smaller bolt to achieve a -1.5 camber. The OEM bolt can only go -0.8 so I used a smaller bolt.
Looking and reading at the pictures and threads, 2001 is different from 2002. Again, according to Mex, 2003 is the same as 2002. However, my 2004 is totally different from 01,02, or even 03. I will have to take pic, I just keep forgetting my camera.
What I dont get is, the online parts store lists 2001-2003 at the same model year. Or has having to use the same part [?] For example, I ran a query for a 2003:
STRUT BEARING, Civic, 2 Door, 4 Door - 2001-03 $17.52
SPRING INSULATOR, Civic, 2 Door, 4 Door, Upper - 2001-03 $10.84
SPRING INSULATOR, Civic, 2 Door, 4 Door, Lower - 2001-03 $13.99
STRUT MOUNT, Civic, 2 Door, 4 Door, Right - 2001-03 $26.51
STRUT MOUNT, Civic, 2 Door, 4 Door, Left - 2001-03 $21.55
But on the left column of the above parts that indicates for which year is printed as 02-03
I ran another query for the 2001, here are the results:
STRUT MOUNT, Civic, 2 Door, 4 Door, Right - 2001-03 $22.57
STRUT MOUNT, Civic, 2 Door, 4 Door, Left - 2001-03 $22.57
STRUT BEARING, Civic - 2001-03 $13.45
SPRING INSULATOR, Civic, 2 Door, 4 Door, Upper - 2001-03 $8.82
SPRING INSULATOR, Civic, 2 Door, 4 Door, Lower - 2001-03 $10.31
Left column indicates that the above parts are listed for 2001 only.
Okay, we should follow the column for model YEAR and not the 2001-2003 description.
I forgot what I was trying to do here I dont even know if I was trying to prove something or whatever...I just lost myself
I dont think we need all those parts, I just want to list them for whatever
Anyway, I'll take pic of my 2004 tomorrow.
Old Jul 23, 2004
  #44
518's Avatar
518
B&G S3 received today!!!
I and Jeff couldnt believe it!!!!
I gotta go inspect it since theres a minor rip on the box, !@#$% UPS guy!!!
Old Jul 23, 2004
  #45
518's Avatar
518
Initial Impression:
1. The packaging is top notch. Seems like thats part of the B&G certification
2. TIG welded and cleaner than your ordinary TIG welding job
3. Very nice finish
4. The knuckle bolt is indeed smaller than stock. I could probably fit the smaller bolt that I am using, camber purposes.
5. I think the springs need to be compressed to fit the strut mount. So, that means profesionally installed is highly recommended.
6. Bracket for brake lines. Its a two piece independently welded unlike the OEM which is one piece and welded on the strut.
7. Anodized locking perches
8. Grey Coated springs
9. Tie-rod end is just like the OEM, insert from top.
10. No install instructions and locking wrenches included [?]
Old Jul 23, 2004
  #46
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Initial Impression:
3. Very nice finish
I'll make the call on those wrenches. Where would you like them sent? PM me. I'g glad you are happy with them.
Old Jul 23, 2004
  #47
518's Avatar
518
Jeff,
I sent you a PM.
For those of you who needs a B&G, you may want to get it from StreetLevel.
Old Jul 23, 2004
  #48
ironcow's Avatar
can you beat 780 shipped?
Old Jul 23, 2004
  #49
518's Avatar
518
where in the world did you get that price? This isnt Hayame bro
Old Jul 23, 2004
  #50
Your Parts Guy
That made me laugh
Old Jul 23, 2004
  #51
2k2EXCOUPE's Avatar
TUCKIN 19s
This thing with the wrenches in weird...
518- I didnt get mine either... as for install, i just kinda went with the flow and guessed with some help of Riley- easy install...
Jeff had my wrenches shipped and should be here any day now...Definately a good shop to deal with guys!! Highly recommended.
Old Jul 23, 2004
  #52
518's Avatar
518
Yeah, great thing that we are being taken care of by Jeff.
Anyway, we do need to compress the springs to install them, no [?] Or it should sit flushed as I lower the perches? What else do I need to watch out for?
thanks.
Old Jul 23, 2004
  #53
2k2EXCOUPE's Avatar
TUCKIN 19s
thanks.
No need for a spring compressor, I just had my dad push down while put on the upper mount.
Not much else you need to watch for I dont think, i went from Tein SS to B&G's so the install is a little different for me. I am still getting some noises up front, but I think its from the ride height washer things (lol i dont know the name of it) not being tight enough together since I didnt have wrenches, I hand tightened, and I heard if they arent tightened hardcore they make noise...Least thats what Im hoping it is...
Old Jul 23, 2004
  #54
518's Avatar
518
I am also concerned about the knuckle bolts. The knuckle on this B+G looks smaller than the OEM hole when I compared them side by side. But if they do align well with the knuckle even if its smaller, I am all set.
Both the front and rear upper mounts have been re-used, correct?
thank you for your replies bro.
Old Jul 23, 2004
  #55
2k2EXCOUPE's Avatar
TUCKIN 19s
No problem man- Always glad to help!
I didnt have any problems with the knuckle bolt, nor did I know it was supposed to be an issue? I know the rear was a bitch to line up the bolts but we did it, definately need 2 people for an install, makes it much easier. To finally get the rears alligned I literally stood on the drum to press it down while my Dad jimmied the damn bolts. Took a few minutes but it worked (with WD40 to lube it up).
Front and rear uppermounts (stock) must be used. I have an 02 and already had replaced them with 01 front upper mounts for the Teins so I left those on (dunno what happened to my 02 mounts).
Old Jul 25, 2004
  #56
Your Parts Guy
518 and 2k2 your wrenches are on the way.
Old Jul 26, 2004
  #57
ironcow's Avatar
well thats what i paid for mine so sorry
damn
Old Jul 26, 2004
  #58
518's Avatar
518
damn
sure
Jeff,
Got them, thanks.
Old Jul 26, 2004
  #59
Your Parts Guy
sure
Jeff,
Got them, thanks.
NP
Old Jul 27, 2004
  #60
ironcow's Avatar
ill post the invoice later tonight
