Tein HA for RSX and EP3
Old Jun 22, 2004
jdm_bb's Avatar
jdm_bb is an unknown quantity at this point
I know that the tein for the RSX and EP3 can be modified to the 7thgen
My friend is going to sell me his tein HA for a really good deal.
I just want to know what I'll need to do to put this suspension on my 7thgen
and I have an LX coupe.
Thanks
Old Jun 22, 2004
robbclark1's Avatar
Retired suspension supermod.
There is no listing for either the DC5 or the EP3 for Tein HA.
If it is for the EP3, then it should swap right in. You may need to cut a hole in the skeleton of your hood. The DC5 would require some work. The ball joints are larger on the RSX i believe.
Old Jun 22, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Tein DID make DC5 Type HA coilovers. They were then determined to be way too stiff for road use after the fact, so they replaced them with the Flex model.
Old Jun 22, 2004
Zzyzx's Avatar
Autocross Junky
Street tires Dont react well to High spring rates.... THough I did find one listing of the DC5s HAs spring rates... and they are only 392/504 so they aren't that stiff. If they were the N1s then I would avoid them for all but Track use (1007/1567)
Old Jun 22, 2004
robbclark1's Avatar
I shoulda got those N1's!! haha...
Old Jun 22, 2004
Zzyzx's Avatar
Autocross Junky
Depends if you like your fillings were they are now... ( rattle Rattle Rattle...)
Old Jun 22, 2004
jdm_bb's Avatar
RSX and EP3 are the same though so is that mean i can just get this install...
what 'll I have to look after..?
Old Jun 22, 2004
slowvic's Avatar
slowvic is an unknown quantity at this point
you probably need a rollcage to take advantage of those spring rates.
Old Jun 23, 2004
robbclark1's Avatar
No they aren't. The tie rod ends are a different size and so are the mounting bolts to the brake hub. I know there are a few little things that are different.
Old Jun 23, 2004
jdm_bb's Avatar
so is that mean if i want to change to that setup i have to change alot of stuff?
Old Jun 23, 2004
robbclark1's Avatar
No. They will bolt in, but you might have to get a few bolts or RSX tie rod ends. If it is for the EP3 then it "should" swap right in.
Old Jun 23, 2004
sheizen's Avatar
sheizen is an unknown quantity at this point
if it wasnt made for you car dont buy it, especially tein coilovers.
Old Jun 23, 2004
robbclark1's Avatar
Completely FALSE!! A few of us have JIC coilovers for the EP3 and some people have the Flex for the EP3. The DC5 ones require a little more modifications but they fit. Just like older integras and civics. they share chassis, they share suspension parts.
Old Jun 23, 2004
dj02's Avatar
WERD!
JDM_BB u can PM em2guy he had full rsx suspenion on his car. i know he only had to change the tie rod ends and some bolts. forgot what he had to do, to the rear. but yes it can be done.
Old Jul 5, 2004
whitevic's Avatar
whitevic is an unknown quantity at this point
Originally Posted by dj02
WERD!
Agreed! I only had to put on tie rod ends for the TODA Fightex's to bolt on (I have DC5-R brakes as well though).
GolNat
Nov 27, 2018 03:32 PM
PunX
Sep 23, 2015 10:45 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
EM_WON
Jul 22, 2015 06:49 PM
