16" vs. 17" tires and suspension
Old May 15, 2004
sffree's Avatar
sffree is an unknown quantity at this point
I have 205-55-16s.. and wanted to go 205-50-17s.. would the 'better' handling really be that noticeable? Would replacing both wheels and tires be worth the benefit?
Old May 15, 2004
Zzyzx's Avatar
Autocross Junky
Depends on how stiff the new tires side walls are. Example, I autocross on a set of 205/50-15 and drive on the street with a set of 215/45-17. and the Grip and stability of the 15s is MUCH more the the 17s, because of the design of the tire.
also, I think the perfromace loss in accleration, Braking and Increased unsprung weight that 17s will give you will offset any real Handling advantage.
Old May 17, 2004
GaryC17's Avatar
GaryC17 is an unknown quantity at this point
What tires are those you using for 15inches ? Need some real stiff side walled tires.
Old May 17, 2004
Zzyzx's Avatar
Autocross Junky
Falken Azenis, Only tires with stiffer sidewalls are Full R compound race tires.
EdGasket
40
Nov 27, 2015 11:11 AM
alaga
25
Aug 13, 2015 04:42 PM
Strycker
Aug 2, 2015 08:40 PM
Misfit2613
Jul 30, 2015 09:49 AM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
