hayame coilover/camber kit question
Old May 14, 2004
R3DL1N3's Avatar
if read different things and was wondering if i was to get hayame coilovers would i need either a front or back camber kit?
Old May 14, 2004
cryption's Avatar
2003 Nissan Frontier
with any coilovers you will depending on how low you go
Old May 14, 2004
robbclark1's Avatar
Retired suspension supermod.
Straight from the FAQ
You dont NEED a camber kit even with a 5" drop. however, with any type of drop(even if its .5") you should get one in order to get a correct alignment. most people will say that with a drop lower then 2", a camber kit is HIGHLY recommended. just think of it this way would you like to save $200 by not getting a camber kit but replace your $400-500 tires twice a year? just invest in a camber kit, it'll save you in the long run.
Old May 14, 2004
scatman's Avatar
Still in the game...
you dont need a front camber kit with the hayames.....the upper bolt hole (where the two big bolts go) is slotted so you can adjust the camber right there...you might want to invest in a rear one tho
Old May 14, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
i just invested in a rear 1 and installed it today, and now have to buy 2 new rear tires. dont b an idiot like me get the rear camber kit, u shouldnt need a front 1.
Old May 14, 2004
flipBloodracer's Avatar
flipBloodracer is an unknown quantity at this point
yup no need for front camber kit just the rear...you need to drill the holes 16mm for the bolts to fit...
Old May 15, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
YES NEED THE FRONT!!!!!!! ITS ONLY 20$ GET THEM
Old May 15, 2004
cryption's Avatar
you don't need the front, I didn't use one. When you have your car aligned after the install that also takes care of the camber issues
Old May 15, 2004
scatman's Avatar
no front. get rear to be safe. done
Old May 15, 2004
cryption's Avatar
aye
civic98?
Aug 13, 2015 01:32 AM
j-chest
Jul 31, 2015 01:18 PM
DerbyDad03
Jul 27, 2015 11:34 AM
NoobyKid
Jul 13, 2015 07:53 AM
chrisjackson321
Jul 12, 2015 03:00 PM
