stability issues
Old May 6, 2004
grbudd's Avatar
grbudd is an unknown quantity at this point
stability issues
i searched and read the faq, can't find anything. At higher speeds my car 02 ex coupe seems to be somewhat unstable. Like it floats side to side somewhat, I have stock suspension and want to upgrade to fix this. Any ideas on what would help this and overall handling?? Thanks for any input and ideas.
Old May 6, 2004
robbclark1's Avatar
Retired suspension supermod.
what do you mean it floats from side to side? Does it go to one side or both? I would suggest getting an alignment. If it feels like it is floating then the toe maybe pushed out.
Old May 6, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
At higher speeds
Define this.
Some of the floating is due to the MacPherson Struts. Just by nature they tend to do that.
You can add reinforcement bars, change sway bars, get stiffer springs, etc... and get some help out of it, but the struts will still make the car wander a little. Better tires also help and the road surface makes a big difference in this too.
Old May 6, 2004
grbudd's Avatar
It started to do it after my blown shocks were replaced and an alignment were done. It happens at speeds over 60 up to 90 around 100 it doesn't do it. it doesn't pull to one side it just feels loose. And I put on new tires too
hans.pcguy
Jul 12, 2015 12:19 PM
werdnahall
May 17, 2015 11:37 AM
PiCASSO
Mar 10, 2002 01:34 PM
RiCeGrL
Feb 21, 2002 09:07 PM
CapYoda
Nov 11, 2001 05:17 PM
