Poly Bushings
Old May 5, 2004
CRNewson's Avatar
CRNewson is an unknown quantity at this point
Poly Bushings
Does anyone know about replacing the stock rubber bushings with polyurethane ones? Any info would be helpful. Another question is, what are the dimensions of the bushings. I work in a machine shop, and I was thinking of making my own, but I don't know what size.
Thanks
Old May 5, 2004
robbclark1's Avatar
Retired suspension supermod.
I don't suggest making your own except for maybe filling in OEM motor mounts. The rears are a pain and you will need other parts besides the bushings (metal inserts). The fronts must be pushed out with a press. for $80 you can get the whole set of front and rear control arm bushings by ES. If you have irregularities in your made bushings then that can cause problems.
Old May 5, 2004
EternalVTEC's Avatar
EternalVTEC is an unknown quantity at this point
rob, i take it you have the front and rear bushings(if not never mind), what are the por's and con's from your experience? overall opinion?
thanks
Old May 5, 2004
liljoe's Avatar
liljoe is an unknown quantity at this point
cool, i'm looking into getting the Energy Suspensions bushings as well. Does anyone have the front and rear sway bar bushings upgraded? I was just wondering if there was any noticable difference?
Old May 5, 2004
robbclark1's Avatar
I have both, yes, but only the rears are installed. I also have poly sway bar bushings. The rears are a BIOTCH to install. They take a lot of work and one even has to be burned out. The fronts are easy. Take the control arm out, get to a press, have them press it out, press in the new one and go. Zzyzx has the front ones installed.
The rears however, have little metal connectors that go in between them so the bolt can run through them. They also come in 2-3 pieces with one middle and 2 surrounding the middle.
It is hard to give my opinion because i also put my coils on at the same time since everything would be apart. The rears will take a whole weekend and you need a propane/butane torch and a vice grip attached to something stable. I liked doing things to my car to learn so to me it was worth it. I also got to hang with my buds, but because I autox the rubber bushings were bound to go eventually so I upgraded them. No complaints so far.
Old May 6, 2004
liljoe's Avatar
cool.
do you know if it is similar to the rear's in a crx? because I've done that on a friends car, and it was a real b*tch! But at least we have a little experience at it now.
Old May 6, 2004
Nokturnl's Avatar
Crawlin Similar To An Ant Low To Da Earth
Nokturnl has a spectacular aura aboutNokturnl has a spectacular aura aboutNokturnl has a spectacular aura about
Just a little FYI for you guys....so you don't do what I did!!! The fronts MUST be pressed out by a machine shop with a multi ton press...the front ones I am refering to. I caused $800 damage to my whip by fudging them up, broke the driver cv joint in two and killed the lower ball joint. Spent over $400 in parts!!!The backs went in with about 1 hr work...not bad at all. The result is quite nice...slightly stiffer ride but the steering response is much quicker. Trust me it is worth taking the fronts to someone and not trying yourself....I did and it killed my front end! Just a little heads up. Over all it is a really good investment. I do recomend getting access to a lift though.
Old May 6, 2004
Nokturnl's Avatar
oh...and get the front poly bushings pressed in too....can't do with out a multi ton press once again!
Old May 6, 2004
Zzyzx's Avatar
Autocross Junky
Ya mean like this.....
Oh! I can see one of my race tires!!!!
Old May 6, 2004
UltimateStock's Avatar
UltimateStock is on a distinguished road
anyone have an idea about hwo much it would cost to have someone install those??? thanks guys
Old May 6, 2004
robbclark1's Avatar
It depends. Some people say $50-75 total from their experiences. I have called around and been quoted $60 per bushing!! That is why i haven't done it yet.
Old May 6, 2004
dag...per?! ...i wouldn't mind 100 all around. plus the parts are only 80 for the bushings right? dag...hmmm....i mean. i don't do any auto-X and i probl won't with this car. but i wouldn't mind ahving better handling. i think i wanna go for a 1.8t in the next 3 years. prob. a gti. word. but the civic is an 8 second 0-60 right? the 1.8 is only 7.5. boooooo. o man...i need food.
STOCK!
Old May 11, 2004
rob, if you want i can talk to my buddy, he works at a honda dealership. ill see what he says. ill call them and get a quote as a regular customer, then ill see if he would do them in his spare time. you interested?
Old May 11, 2004
robbclark1's Avatar
Where is the dealership? Does he have a press? I would be interested if it was a good enough price.
Old May 12, 2004
Faulkner Honda, its in Harrisburg, PA ill let ya know
Old May 14, 2004
dusto12000's Avatar
dusto12000 is an unknown quantity at this point
who can you get these bushings from?
ThatGuy913
Sep 28, 2015 05:35 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 01:28 AM
czarlun
Sep 14, 2015 08:16 PM
