01 control arms
Old Apr 22, 2004
ren808's Avatar
ren808 is on a distinguished road
01 control arms
just wanted to know if anyone has installed or knows of any aftermarket rear lower controls arms
Old Apr 22, 2004
robbclark1's Avatar
Retired suspension supermod.
yes spc and a few other companies. We have covered this a few times already. they will save you around 4 lbs but do nothing else besides look pretty.
http://www.7thgencivic.com/forums/sh...&highlight=lca
http://www.7thgencivic.com/forums/sh...ighlight=bling
please use the search function. Thank you.
Old Apr 22, 2004
Pharoh's Avatar
Bobaganoosh!
I've seen the SPC's - Very nice
Old Apr 22, 2004
C2i0v0i1C's Avatar
SuperMODrizd
do they make front lower control arms?
Old Apr 22, 2004
robbclark1's Avatar
yes, i think mugen has a set, but that is all i know of.
http://www.kingmotorsports.com/product.asp?detail=1664
Aren't worth it for $550 unless you are really hardcore into racing. Just upgrade your bushings.
Old Apr 22, 2004
C2i0v0i1C's Avatar
SuperMODrizd
those are RSX
Old Apr 22, 2004
robbclark1's Avatar
Originally posted by C2i0v0i1C
those are RSX
same chassis, same control arm. Might have a bolt that is different but should work. You will have to disconnect your front sway bar. It is not worth it. No one is gonna make hardcore products for our car because they don't see the point.
Old Apr 22, 2004
HondaLuver's Avatar
Its a celebration bitches!
there is non, well unless you have spent over 2,000 in suspention parts...
Old Apr 22, 2004
robbclark1's Avatar
i have spent over 2k on suspension & wheels/tires
Unless the civic is pumping out mad amounts of power with a really stiff chassis (ie roll bar, traction bar, strut bars, 600+ lbs spring rates) you have no need for those front control arms. Just get the ES bushings and you will be good to go.
Old Apr 26, 2004
ren808's Avatar
i would have to disagree, i think the control arms are very useful. one of my friends bought aftermarket lcas and he has better stiffer handleing and a smoother ride. for those of you that live in the northern states you would understand that the roads are full of potholes. i know i hate when my car bottoms out. just because you have aftermarket struts and springs/ coilovers that doesnt mean you have a nice suspension or that the rest of the part dont play an important role in your cars handleing....and this is my two pesos
Old Apr 26, 2004
robbclark1's Avatar
The lca's on the past civics and integras are more important because the suspension was attached to them. Our cars don't have that type of suspension. The LCA connects to a larger piece of metal that is part of the whole rear suspension. The LCA for our car won't do much at all. The suspension isn't attahed to it and it doesn't pivot like in older gens. The LCA might help slightly. But again, i speak out of theory and not experience. Personally i think our control arm is pretty good. Swapping out your bushings will do more than a set of LCAs.
Control arms won't keep you from bottoming out. Good shocks, springs, and even bushing will do that. But there is only so much the suspension can take so regardless you will bottom out. I am from the northeast and I know what it is like driving in crappy cities. I am not saying that LCAs won't give you anything, but there are better parts out there for the same price and you should be looking to do those before the LCAs.
Old Apr 26, 2004
HondaLuver's Avatar
YEA!!!
u tell them, but they look soo soo nice....
Old Apr 27, 2004
ren808's Avatar
true , true butt a lot of what ppl say about lcas is contridicting to theory they are not just for looks they bring stiffer ride you are able to mount wider tires which makes for better grip cuz of stance,just to name a few. butt ur point is well taken. you can say lcas are like our fart mufflers without the rest of the piping they are pretty much usless
fart fart fart
Old Apr 27, 2004
robbclark1's Avatar
haha fart fart .
the LCAs for our car won't allow for wider tires. They are really there mostly for show. And the reason they helped on older gens is because they come stock with poly bushings. I really don't want to beat a dead horse here, but the suspension set ups are completely different. Let me try to find some diagrams.
Old Apr 27, 2004
robbclark1's Avatar
see our rear control arm (the thing with the three bolts) is so far away from the rim/tire that it doesn't help with adding wider rims. It attaches the frame and then to a large trailing arm. That is all of the control arm.
here is a pic installed
Old Apr 27, 2004
robbclark1's Avatar
see how the shock is attached directly to the control arm on this integra? that isn't aftermarket but you get the idea.
Old Apr 27, 2004
keffin's Avatar
i do...i do....
check out my ride!
Old Apr 27, 2004
robbclark1's Avatar
Originally posted by keffin
i do...i do....
check out my ride!
did you feel any kind of difference?
Old Apr 27, 2004
keffin's Avatar
http://www.7thgencivic.com/forums/sh...t=control+arms
NO! with the control arms, no difference!!!
just for show!
Old Apr 27, 2004
keffin's Avatar
Old Apr 29, 2004
ren808's Avatar
why is it that when i swapped a rear suspension off a 02 si on to my 01 sedan i noticed a diffrence, could it have been my gf maryjane's fault she said it was 4:20. well now i got 4 disc brakes and i did the addition and subtraction thats like 80hp fart fart fart......
fart muffler
Curtchuk
Aug 5, 2015 02:14 PM
brainwashedmc
Jul 27, 2015 10:05 PM
califcamper
Jul 21, 2015 10:34 PM
Fred65
Wheels and Tires
Jul 14, 2015 06:40 AM
fordover
Jul 11, 2015 09:10 PM
