grey's endlinks need help!
Old Apr 14, 2004
RW_Blaze's Avatar
RW_Blaze is an unknown quantity at this point
i got 22mm sway bar with energy bushings...
i juss recetly installed grey's endlinks and i started hearing more harsh noises on bumps and all... i juss want to kno if that's normal.. i set up the endlink's lenght to same length as factory endlinks... is it suppose to be that way or is there a certain length to set it in grey's endlinks...
pls i need help.. if u experienced this before pls help me! and tell me how u solved this problem...
Old Apr 14, 2004
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
i think its normal..i get some noise...not alot and not all the time, but sometimes i do...try tightening everything more
Old Apr 15, 2004
HondaLuver's Avatar
Its a celebration bitches!
yea, thats the problem when you get a stiffer suspention. you start to hear things squeek and what not...
it will go away, you will learn to ignore it... i personally think it is worth the money
Old Apr 15, 2004
bobbyd's Avatar
bobbyd is an unknown quantity at this point
Yeah, I noticed too and I don't have grey's endlinks.
You should ride in my 90 hatchback! Lowered on coilovers, Tokico shocks, front and rear strut bars. I have so many noises, rattles, creaks, it drives me nuts.
Old Apr 15, 2004
half_n_half17's Avatar
half_n_half17 is an unknown quantity at this point
I've got gray's endlinks and i noticed an increase in squeaks, creaks, and other rattles. Then again i'm pretty sure that my shocks are leaking, which could add to the problem.... there are tradeoffs with a lot of things you can do to your car, some are bearable others will get old really quick.
Old Apr 17, 2004
Grey's Avatar
DIY King
Unlike the stock endlinks, which pack the ball and socket joint in grease and seal it in a rubber grommet, my endlinks are free to float around and do what they wish. I muffled the noise in version #1 with rubber o-rings near the ball and socket joints. This helped a little bit, but it didn't solve the problem 100%.
The stock endlinks are quiet, but they're also weaker and more flexible. People with the Hotchkis endlinks have been having the same problem. Noise. I'm running my endlinks too, and I get some noise as well. I'm constantly improving the design though, and I'm currently working on something that will damped the vibration of the free-floating part.
Old Apr 18, 2004
MadWheel's Avatar
Premium Boosted Member
Mine got really bad in the last week or so alone, any suggestions in bringing it back to the way it was when I first installed the endlinks and rsx-s sway? Im thinkin taking the endlinks off, cleaning everything, spraying some white grease on it then tighten it and throw it all back on. Is that the best approach?
Old Apr 19, 2004
Grey's Avatar
DIY King
Hmm... I think you have version #1, right? The ones with the o-rings. I made a version #2 because of that very problem. What happens is that they get dirty and you have to clean them and re-install them for everything to be tight. Dirt gets into the cracks and then it loosens everything up. I might have a solution for you though. We'll talk at Import Wars, ok?
Old Apr 19, 2004
MadWheel's Avatar
yeah man sounds good thanks bro!
dhuff
Sep 28, 2015 08:35 PM
naokigoffi
Aug 30, 2015 06:19 PM
