What is your camber set to?
Autocross Junky
what are you doing with the car?
If its just used on the street, then less then -1 deg, probably less then -.5
Drag race 0 on the nose
Road race, -1 to -2 on the front (depending on the course) -.5 to -1.5 rear. once again depending on the course.
autocross... as much as you can get on the Front, at least -1.5, rear -.5 to -1.5...
These are just ranges, testing and tuning will give you the best camber angles.
I Queef > You
0 in front and -.5 in the rear for a little bit extra traction. However with 24000 miles on my tires, the inside is eaten up a little. No biggie, just flip them.
Autocross Junky
the Proper camber, caster and toe settings are all dependent on your application.....
and the manuufacturers recomended alignment isnt really conductive of a well handling car... Its designed to keep you safe by, Making the car understeer, and be stable going down the Highway in a straight line, as well as Getting the maximum tire life.....
For a more Performance based alignment you have to be more agressive with the alignments, and From what I've learned, the Proper alignment can mean the difference between an Understeering pig of a car and a Tossable, fun to drive automobile.
Of course finding out what alignment sutis you best means testing and tuning, as with all things. Heres a little reccomendation, Run more negitive camber on the nose then the rear (Some where between -.75 and -1.5 front would probably be good for the street), and possibly run 0 to a little toe out on the front, and 0 toe on the rear... Maybe a little Toe in or out depending on if the car is understeering or oversteering.
happy racing, and keep the shiny side up.
Dave Brabant
20
Oct 6, 2015 12:44 AM
