roll cage
Old Apr 12, 2004
EM2HK1's Avatar
EM2HK1 is an unknown quantity at this point
roll cage
anyone know if they make bolt on rear section roll cages for the EM2? if so where can i get it? i saw one on optauto.com but not sure if its a bolt on or weld on.
Old Apr 12, 2004
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
read the descriptions, its a bolt in
Old Apr 13, 2004
EM2HK1's Avatar
i think its a bolt on too, but the thing is it didnt say that it is a bolt on so i didnt want to assume haha =P
Old Apr 13, 2004
i thing one of the more complete ones says it a bolt in so i just assumed all where...
Old Apr 13, 2004
Zzyzx's Avatar
Autocross Junky
autopower makes a cage for us, its only a half cage, so do be legal for wheel to wheel racing you'll need to 1. weld it in and 2. add door beams as well as a front section (I'm pretty sure autopower makes that stuff too)
Old Apr 13, 2004
CrazyCakes's Avatar
CrazyCakes is an unknown quantity at this point
any idea on what the specs are for a cage/bar in STS
Old Apr 13, 2004
Zzyzx's Avatar
Autocross Junky
Took me a while to find it, as its covered in the stock rules rather then STS..
"Roll bars and roll cages may be added (see Appendix C). It is strongly recommended that they be constructed according to Section 18 of the current GCR. Roll bars may be welded. Roll cages must be bolted, not welded, into the automobile and within the driver/passenger compartment. A roll cage has more than four attachment points to the body or frame, or has bracing both fore and aft of the main hoop."
Rules can be found here...They are slightly out dated (2002) but most of it still applies
STS rules
Stock Rules
The rule regarding Roll cages/bars is covered under 13.2 Bodywork, Section G.
Old Apr 13, 2004
Renamazazo's Avatar
Renamazazo is an unknown quantity at this point
Re: roll cage
I think I see your car at BCC all the time....
robjcivic
Mar 12, 2017 12:10 PM
Tedverseti
Sep 29, 2015 05:41 PM
General DIY
Sep 25, 2015 08:02 PM
Hollywoodsnake
Sep 20, 2015 12:58 PM
mrwhos
Aug 11, 2015 02:03 AM
