Cant Adjust Koni Rear knob
Old Mar 26, 2004
integ108's Avatar
integ108 is on a distinguished road
Cant Adjust Koni Rear ****
i have a coupe and i cant adjust the settings for the rear shocks the **** is to fat and the compartment where the **** goes on is smaller than gary coleman can someone please help me... thanks
Old Mar 26, 2004
streetglower's Avatar
are you using the right ****, there are 2 of them, one is used to adjust the front struts, the other is used to adjust the rear struts.
Old Mar 26, 2004
integ108's Avatar
yeah actually there both the same size ***** and the little metal part sticking out is the same its just cramped in there what can i do ?
Old Mar 26, 2004
I dont know what to tell you, wish I could see it.
Old Mar 26, 2004
flotsamm's Avatar
I had the same problem. The sheetmetal is in the way so you cant get the **** on correctly. Since its only sheetnmetal thats not critical to the integrity of the body I just bent it enough to allow me to get the **** on. I havnet had any problems. BTW mine came with a shorter shank **** for the rears then front *****. But it still required me to bend the metal some.
Old Mar 26, 2004
robbclark1's Avatar
Retired suspension supermod.
they are an allen key correct? Find an allen wrench the same size and use that. It will fit for sure. .
Old Mar 26, 2004
No they are not an allen key.
Old Mar 26, 2004
jdm_bb's Avatar
jdm_bb is an unknown quantity at this point
just use a plier...
Old Mar 27, 2004
sffree's Avatar
sffree is an unknown quantity at this point
my koni installer cut the rear ****.. kinda like a triangle shape... the right side still is a bit hard to manuever.. but it's the only solution unless you use pliers or something..
Old Mar 28, 2004
FattyMcJ's Avatar
Addicted to the Twisties!
NO IT'S NOT!!
Just TAKE A HAMMER TO THAT BIATCH !!!!
That's what I did...and I now have PLENTY of room...don't worry, you're not going to do any SERIOUS damage, unless you use a friggin' SLEDGE HAMMER, lol.
Old Mar 28, 2004
Diablo's Avatar
Diablo is an unknown quantity at this point
all you have to do is like fattymcj syed just hammer the cheetmetal back till it fits i had to do that and i bet almost everyone that gets koni has to do that if they want to use there ****.by the way there is a short *** for the back and a longer one for the front.
Old Mar 28, 2004
integ108's Avatar
man i didnt know there werre 2 different sized ***** i assumed they were the same never noticed the length
Old Mar 30, 2004
blacksheep's Avatar
blacksheep is an unknown quantity at this point
Hahahaha same here I never noticed they weren't the same except one day I adjusted them and the next day I tried again but took the other **** and there was NO WAY it would fit I was like "WTF!?!" that's when I pulled out the other one and noticed the difference
I hammered the sheetmetal tab out of the way too
Tedverseti
Apr 23, 2020 01:45 PM
juror
Suspension DIY
Jul 30, 2019 03:28 AM
GotSiR
Jun 23, 2016 04:06 PM
JohnnyBxo
Nov 12, 2015 03:04 PM
Curtchuk
Aug 5, 2015 02:14 PM
