Springs settle every time car put on jacks?
Old Mar 19, 2004
abmerop18's Avatar
Jam out with your clam out.
i installed my neuspeed race springs last saturday and now it seems every time i jack up the car be it to install the camber kit or put my rims back on as i did today, that the rear springs raise back up when the car is taken off the jacks then settle back down after i drive around a bit. is this supposed to happen or does this mean they just have not fully settled in? i plan on getting my alignment tomorrow too, should i wait longer because they have not settled yet or what? btw, there is no problem with the front, it always settles down to the same height right away. thanks for the help.
Old Mar 19, 2004
VNlilMAN's Avatar
The Standard One
its normal
Old Mar 19, 2004
abmerop18's Avatar
so for everyone the springs will rest higher every time you put the car on jacks, then settle back in after a little bit? do you think i have waited wnough now to get that alignment, or should i wait another week or so?
Old Mar 20, 2004
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
Yeah you should wait a week or so for everything to settle before you bring it in for an alignment.
Old Mar 20, 2004
abmerop18's Avatar
i have waited a week already. do i need to wait any longer?
Old Mar 20, 2004
streetglower's Avatar
no
Old Mar 20, 2004
flotsamm's Avatar
Are you talking about when you lower your car off the jack the tires are cambered until you roll a little bit? If so thats normal. It from the tires gripping the ground while car is being lowered off the jack.
Old Mar 20, 2004
robbclark1's Avatar
Retired suspension supermod.
no he is not. Every time you jack the car the springs decompress. Right now I just got back from jacking up my car and the rear is higher than it was before I jacked it up. It is normal. Drive it around and they will go down.
Old Mar 20, 2004
abmerop18's Avatar
ok, cool. thanks for the info man.
Old Mar 20, 2004
MIT's Avatar
MIT
MIT is an unknown quantity at this point
yeh, same here. when i installed that rsx 19mm bar, my car raised up like an inch...bcz i used jack stands, after a quick dirve...spring back to normal, same height as usual....
so do i needed to re-alignment my car every time after i jack up my 2 front or 2 rear tires?
Old Mar 21, 2004
flotsamm's Avatar
Nah you dont have to. Its just higher until you drive around and the springs get some compression back.
Tedverseti
Apr 23, 2020 01:45 PM
kevin99ek
Apr 23, 2015 09:32 PM
civic_gt
Apr 19, 2015 08:15 AM
McD
Apr 16, 2015 10:46 AM
ImmortalEX
Oct 31, 2001 10:00 PM
