Buying used Konis, have question.
Old Mar 12, 2004
Jodster's Avatar
Post Whore General
I'm looking at buying a set of use Konis from someone and I have a question. He civic is a 01 and mines a 03. Both EX coupes. I know that the 01s use 50 MM and the 03s use 55 MM, but the struts are assembled in the 01 housings. Will they fit on my 03? All I will have to use is the upper strut housing from my 03. Anyone know? I want to buy this like tonight. Thanks.
Old Mar 12, 2004
VNlilMAN's Avatar
The Standard One
Well the only problem I see is the "camber bolts" maybe a different size...
I believe 01-02 uses 14mm bolts while 03-04 uses 16mm ones(well its possible some 03s still use 14mm)
You would have to drill the two holes on the strut bigger in order for it to fit.
Old Mar 12, 2004
Zzyzx's Avatar
Autocross Junky
question..... Hes taking out his konis and swaping them with what? Its not like He can put his stock struts back together, so why dont you just take his whole 01 front strut asembly and use that? then you would have the konis in their proper housing and have your stock struts around for backup if needed.
Old Mar 12, 2004
Jodster's Avatar
Post Whore General
He got different factory suspension. I'm getting everything but the upper strut housing and bolts
Old Mar 12, 2004
VNlilMAN's Avatar
The Standard One
Zzyzx, i think your confused(either that or i am)...
I think Jodster's getting the koni's along with that guys 01 housing. He's just not getting the uppermount. Which shouldnt be a problem cause he can just use his 03 uppermounts.
Old Mar 12, 2004
Jodster's Avatar
Post Whore General
^^^^^^^^^Yes, the Konis are still in the 01 strut housing. All I have to use is my 03 upper housing. I just didn't know if it would be a problem due to the 01s needing the 50 MM and the 03s needing the 55 MM. But I'm getting the strut assemblied in the housing. So its going to be an easy swap.
Old Mar 12, 2004
VNlilMAN's Avatar
The Standard One
I didnt even know the 01s and 03s used different ones but i'm 95% sure on this...
reason why 01s use 50mm is cause their housing are smaller than 03s. But ya since your using 01 koni's in 01 struts your fine. only problem is does the 01 struts fit the 03 model perfectly fine. Answer as far as i know is NO. again, only difference being the size of the lower holes
Old Mar 12, 2004
Jodster's Avatar
Post Whore General
how hard is it to drill the bolt holes bigger?
Old Mar 12, 2004
VNlilMAN's Avatar
The Standard One
have no clue... it seems easy and people say its easy but honestly, i have no clue how i would do it... It would have to be directly in the center cause if its off, the bolts arent going to line up right.
Cause you know how you insert a bit and you drill and it starts cutting 1 side faster than the other and then it gets messed up... you would think it cuts everything evenly but ya sometimes it doesnt work out that way
Old Mar 12, 2004
Jodster's Avatar
Post Whore General
what size bit would I need?
Old Mar 12, 2004
VNlilMAN's Avatar
The Standard One
16mm i believe... well who knows you might not even have too.. i'd say check if you actually need it before you buy the bit
Old Mar 12, 2004
Jodster's Avatar
Post Whore General
ok
Old Mar 14, 2004
VNlilMAN's Avatar
The Standard One
hmm.. i think you can use a tapered bit... lol i saw it on west coast choppers...
Old Mar 14, 2004
Jodster's Avatar
Post Whore General
Ha, Well i should get them mid this week. So, I see what I have to do then. Thanks for the help again.
Tedverseti
Apr 23, 2020 01:45 PM
juror
Suspension DIY
Jul 30, 2019 03:28 AM
viperGTS
Jul 27, 2015 08:40 PM
viperGTS
Jul 27, 2015 08:38 PM
DerbyDad03
Jul 27, 2015 11:34 AM
