front camber bolt
Old Mar 7, 2004
abmerop18's Avatar
Jam out with your clam out.
Question front camber bolt
wtf does this think actually do?? i installed the fornt part of my suspension today with my neuspeed race springs and spc camber kit and it just seems like this bolt does absolutly ****. i dont even get to replace both bolts on each side, only one of them and the spc bolt is same thing only one nut is 15cm instead of the normal 17cm plus it has that weird looking washer thing. does this really help at all or did i waste the extra $20 to buy the full camber kit. btw, i plan on finishing up the rear suspension later in the week when i get a chance.
Old Mar 8, 2004
VNlilMAN's Avatar
The Standard One
ya it only replaces one.. it doesnt work? cause your doing it wrong...
loosen the stock nut(not take out) now turn the camber kit, you'll see the camber changing..
Old Mar 8, 2004
abmerop18's Avatar
well, i didnt really mess around with it or anything, i was just saying by looks that it looked just basically like stock. im just gonna take it to NTB this weekend when i finish my rear suspension so they can asjust the front and rear.
Old Mar 8, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
dude damn man dont be rude unless u look at it first it adjusts it alot... u turn the one side and its a offsides bolt which changes camber it workx be faithful..
riley
Old Mar 8, 2004
flotsamm's Avatar
You have to loosen the bottom bolt and then adjust the camber using the top bolt. The camber bolt has an eccentric on it that pushes the steering knuckle in or out depending on which way you want to adjust the camber. Once the camber is set, you tighten the bolts.
Old Mar 9, 2004
GaryC17's Avatar
GaryC17 is an unknown quantity at this point
flotsamm, What about the funny looking washer ? It has this little protruded part that goes into the bolt hole. Are we suppose to position it directly opposite of the eccentric ?
Old Mar 9, 2004
flotsamm's Avatar
Not exactly sure. Which kit do you have?
Makeice3498
Jul 2, 2015 11:13 AM
PierrePierre
Jun 17, 2015 06:22 PM
ayzan
17
Jun 30, 2002 12:36 PM
ernhole1
Dec 6, 2001 12:05 PM
ImmortalEX
Oct 31, 2001 10:00 PM
