Part #'s for 02 front camber bolts
Old Mar 4, 2004
zinkyroo's Avatar
cool beans
zinkyroo is an unknown quantity at this point
Hi I recently swapped Boilermaker's Stock 02 suspension into my 01 coupe, and currently Im using the SPC adjustable camber bolts, but I want to replace them with the stock bolts. Does anyone know the part #'s for the 02 camber bolts? Thanks
Old Mar 4, 2004
zinkyroo's Avatar
cool beans
anyone?
Old Mar 4, 2004
HondaLuver's Avatar
Its a celebration bitches!
i beleve the stock bolts should be the same. because the spc bolts are the same for your 01 and are working on a 02 suspention.
its the same as your stock.
the ones that are diffrent are the si's bolts in the front, the rear si bolts are the same in the back, i believe
Old Mar 4, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
http://www.hondaautomotiveparts.com/...SHOCK+ABSORBER
Part 12 is the crash bolt, 14 is the nut.
Old Mar 7, 2004
zinkyroo's Avatar
cool beans
do I need 4 because i thought i only needed 2
Old Mar 7, 2004
Jap-Euro Fusion
I think with the camber kits you only change the top bolt on each strut. So if you still have the other 2 then you'll just need 2 more.
Old Mar 8, 2004
VNlilMAN's Avatar
The Standard One
those part numbers are different from the dealers... they use the same system tho and should be able to figure it out for you.. i had to order some bolts but handa charges like a $7 fee for ANY order so ya i just went with the dealer
usajags84
15
Aug 19, 2015 03:12 AM
bsmiley
Apr 27, 2015 01:27 PM
bo_red
Apr 23, 2015 10:09 PM
ernhole1
Dec 6, 2001 12:05 PM
ImmortalEX
Oct 31, 2001 10:00 PM
