ok guys help me out....
Old Mar 4, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
i have B&G coilovers dropped to the max.
no sway bars,
nothing else just the drop (suspension wise)
my dilemna is when i go to switch lanes real fast or w/e my rear end wants to slide out or it jumps around on me... suspension is firm, very firm but when i yank it it just feels like its going crazy back end slips out and bounces around then comes level again.. what can i do to stiffer or w/e i need to do..
riley
Old Mar 5, 2004
HondaLuver's Avatar
Its a celebration bitches!
at what setting is ur rear at because if it is too stiff, i understand it will want to slide because it can't absord the bumps in the road, if you make it softer, it should help. if you make it softer, you also run the risk of having alot more rubbing since ur dropped so much
Old Mar 5, 2004
half_n_half17's Avatar
half_n_half17 is an unknown quantity at this point
You could put a bigger sway bar in the front... or disconnect the one in the back (if you've got an ex).
Old Mar 5, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
ive got lx.
Old Mar 5, 2004
Zzyzx's Avatar
Autocross Junky
what are you doing while quickly changing lanes?? It could be as simple of a fix as changing how you drive .
Also, from what you've described... the car may simply be to low.
Old Mar 5, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
i quick change lanes when i need to get across 7 lanes on US19 busy *** road crazy people... gotta move quick. anyways when i drive normal its fine.. idk when i drive craazy it acts weird oh yeah and.... my car makes noises sometime like noises from the engine/transmission.. could the drop affect my drivetrain? idk i know that cars are made to be adjustable and still "drive" if u had alot of weight in it but idk it just seems like it wants to die on me sometimes makes nasty noises
riley
Tedverseti
Apr 23, 2020 01:45 PM
LSC
Jun 22, 2015 11:29 PM
Reginator
Jun 17, 2015 07:54 PM
wsking77
Aug 29, 2001 05:34 PM
