HELP front upper strut bar
Old Feb 10, 2004
tripledoublegs's Avatar
Euro-Spec
I need help installing my front upper strut bar. For some reason, it doesn't want to clear the brake fluid thing on the driver's side. what should I do??
Old Feb 10, 2004
half_n_half17's Avatar
half_n_half17 is an unknown quantity at this point
cut it off... who needs brake fluid? Seriously tho... i think you can move it out of the way. I've read in this forum somewhere about how/where to move it.
Old Feb 10, 2004
Euro-Spec
ok, I finally pushed it out of the way but do you guys think that thing has to stay straight or something??
Old Feb 10, 2004
robbclark1's Avatar
Retired suspension supermod.
no, all of ours are either relocated or pushed out of the way. Mine is.
Old Feb 10, 2004
Euro-Spec
ok, thanks
Old Feb 11, 2004
clownprince's Avatar
Ricerus Maximus
you can lower it. Just have to modify the bracket it's on with a little bending and it will go in the hole below the one it's in. takes 2 minutes tops.
Old Feb 11, 2004
Yoyoio's Avatar
Yoyoio is an unknown quantity at this point
I have a 03, i don't know if this will make a different. Below the brake fluid bracket there's another bolt. No mod needed, just put it down on bolt and will clear everything.
Old Feb 11, 2004
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
mine cleared fine when i installed my neuspeed. No problems with the brake fluid resevior.(sp?)
Injen
GH04si
Apr 15, 2015 08:13 PM
Daniel420
Dec 4, 2001 08:46 PM
0100010
Bolt-on Engine Performance
Nov 26, 2001 07:50 PM
PlatnumBomb
Nov 9, 2001 01:11 PM
andylao
Nov 4, 2001 01:19 PM
