Suspension/steering clicking?
Old Feb 9, 2004
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
Ok guys, I have searched this, and I hope its not my CV joints that are messed. lemme describe first:
upgrades:
progress front and rear sway bar/tie bar combo
hayame full coilover set
Velox 17x7.5 wrapped in 205-45-17 kumho tires
problem:
when ever i turn the steering wheel going at SLOW speeds (~5-10 mph) i will hear a click if i turn the wheel past 1.5 turns, this happens in both directions. sometimes it clicks ones, sometimes twice, as i keep turning the wheel, it will click more...sometimes it doesn't click at all. when i'm making turns @ 40+ mph, there is no sound...it could be still there but drowned out by the engine noise.
and VERY RARELY, if i go over a speed bump, it will click, and squeal which sounds more like the sway bar bushing making noise.
so guys, is it my suspension settling? cv joints screwing up? or what?
All help appreciated! thnx in advance
Old Feb 9, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
I'm not sure... but my JICs do it every once and a while. I was told to let it settle and there's probably some grease that needs to get smeared around in the bearing. How long has it been going on? Maybe try tightening everything up again.
Old Feb 9, 2004
§C§H§O§C§O§B§O
its been going on for a couple weeks only
Old Feb 9, 2004
§C§H§O§C§O§B§O
my GC's had the spring settling problem, but GC's are different, the coilovers can bounce on their perch if you hit a bump of some sort. The hayames won't do that, so would spring settling be an issue?
Old Feb 9, 2004
VNlilMAN's Avatar
The Standard One
click or popping? did it do it before the hayame install?
if problems point to hayames just make sure the 3rd locknut is tight, very tight.
If you jack up both sides of the car and turn the wheel you'll hear the sound if it is the 3rd locknut
Old Feb 10, 2004
§C§H§O§C§O§B§O
awesome...i'll tighten it first thing tomorrow morning...and i had those sounds with GC's, but went away for a while with the hayames, now they're back... i'll tighten all bolts and nuts while at it.
Old Feb 10, 2004
Pedro Lopes's Avatar
Pedro Lopes is an unknown quantity at this point
Hey chocobo 15_2000 how do you like the Hayame coilovers so far. I'm thinking about getting them. Thank you.
Old Feb 10, 2004
and how low did you set your car
Old Feb 10, 2004
§C§H§O§C§O§B§O
i like ALOT!! they are REALLY nice... and mine is dropped about 1 in. I have a 2 finger gap in the back, and ALMOST 2 finger in front. I no like slammed, so 1 in is more than enuf for me.
Old Feb 15, 2004
streetglower's Avatar
just take it to a shop and have them check it out, usually they will find the problem.
Old Feb 22, 2004
draganjr's Avatar
draganjr is an unknown quantity at this point
i have a popping/clicking noise when i turn left and cut back. Everything is stock. i jacked the car up and there is nothing wrong, no play anywhere and no grease?
any ideas?
thank you.
Old Feb 23, 2004
Jap-Euro Fusion
Raise the car up, tighten the lower locknut, and re-tighten the tie rod bolt.
Those are the 3 possiblilities.
carid
Sep 28, 2015 10:13 AM
Skunkone
Sep 24, 2015 04:38 PM
charmon4815
General
Sep 22, 2015 08:00 AM
Juanb24
Sep 15, 2015 12:39 AM
Josh 1973
Sep 7, 2015 10:10 AM
