strut bar install throwing off alignment?
Old Feb 7, 2004
GoBruin02's Avatar
GoBruin02 is an unknown quantity at this point
Hey guys
I recently installed a neuspeed front strut bar. In order to fit it properly, I had to jack up the driver's side of the car and loosen the inner nut. The outer two nuts were already completely off and I had to loosen the third one to move the bolts enough to align with the strut bar.
Anways, I've been driving the car and it handles great!! I did notice though that the car seems to be pulling a little more than usual. Could the installation of the strut bar or the strut bar itself be throwing my alignment off?
Old Feb 7, 2004
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
mine does the same thing but i dont know if its due to the strut bar. i also have the neuspeed along with the progress anti-sway, but i am just gonna wait till my new rims arrive and worry about the alignment job then.
Injen
Old Feb 7, 2004
HondaLuver's Avatar
Its a celebration bitches!
all you had to do is unbolt the top bolts in the engine bay... why did you do all that extra stuff... and everytime you mess with ur suspention such as taking something off and on like shocks,even to the same height, you are messing up with the alignment...
Old Feb 7, 2004
tfnaaf's Avatar
BLDNPSI Mod
It's possible to get some movement in the top of the strut after you losen the mount bolts. This CAN give a change in camber/caster. Granted very little but ther is a possibility that it could make enough difference to cause a pull afterwards. I would suggest getting the alignment checked to be on the safe side.
Old Feb 8, 2004
usafstud's Avatar
ur not suppose to lift up the car for the installation of the strut bars
http://www.neuspeed.com/data/installs/35.20.48.pdf
looks like ur going to have to go to the alignment shop
Old Feb 8, 2004
VNlilMAN's Avatar
The Standard One
man lookin at the car the wrong way can throw off the alignment...
Old Feb 8, 2004
HondaLuver's Avatar
yea it can vanilla man
Old Feb 8, 2004
dret's Avatar
President
dret is an unknown quantity at this point
Lifted up the car? why'd you do that.. was it a neuspeed strut bar?
Old Feb 8, 2004
injencivic's Avatar
as per the instructions from neuspeed, if the drivers side doesnt align completly over the struts raise the car to where they will be aligned above the struts. Do you have a neuspeed front strut bar?
Injen
Old Feb 8, 2004
usafstud's Avatar
Injen
what are u talking about? i just checked all the neuspeed front upper strut installation and i don't see anywhere that it says to left up the car
if u lift the car and take the strut bolts off, u can miss up the alignment
Old Feb 8, 2004
GoBruin02's Avatar
yes I have a neuspeed strut bar and yes the instructions in the box told me to jack the car up if the bar didn't fit properly.
bluecoupe
Nov 28, 2001 08:21 PM
0100010
Bolt-on Engine Performance
Nov 26, 2001 07:50 PM
CapYoda
Nov 20, 2001 10:36 PM
PlatnumBomb
Nov 9, 2001 01:11 PM
andylao
Nov 4, 2001 01:19 PM
