Question on Grey's Endlinks?
I have a Rsx-s and I am using a JDM 22m sway bar.
I just ordered 2 for the rear.
1. How long does it take to usually ship out and arrive at my house. Im in Cali.
2. I heard something about needing rings, Can I just use these on my rsx with the type r swaybar the way it is?
Thanks
Chris
Thanks
Chris
Originally posted by Sickboy
I believe so, I got mine only a month or two ago. It came with instructions, e clips, c clips, and washers.
I searched and all his forums about the revo ss upgrade kit dont work.
The rubber-backed washers go around the main linkage, and do help with the front to back play in the shifter. The E clips replace the OEM cotter pins that keep the main and secondary linkage attached to the shifter. The C clips hold the main linkage cable stationary where it goes through the base of the Revo. It's worth $6 IMO. And, there is inherent play in the design of our shifter so you can't get all the play out with any kit.
Hopefully Grey will answer my Pm,
Thats my only chance to get the kit.
i know he isn't on that often, but next time handle it through email or PM. He could answer all of these questions a lot better than any of us. Thank you.
