Those with JIC Magic Coilovers, some help please!
Old Jan 28, 2004
Hwoody77's Avatar
Hwoody77 can only hope to improve
Hey everyone I have JIC Magic coilovers and on the front the **** is about half an inch from poking out of its hole...it can hit the boot I hear people say...
So my question is, if I leave it like this can I get a 3 inch drop and full shock travel?
Or is it the more down it goes the worst the shock travel gets... if that's the case will I bottom out with it like this?
Old Jan 29, 2004
dragin's Avatar
dragin will become famous soon enoughdragin will become famous soon enough
never heard of that....hmm ill have to check mine see if they do that as well...
Old Jan 29, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
With JICs the shock travel is independent of the ride height. When you lower the ride height, all you do is thread the lower mount further up the shock body, which is why your adjustment **** is starting to stick out. Thats also why JIC says the adjustment range is from .5-2.5"... and it does get in the way of the boot.
Old Jan 29, 2004
VNlilMAN's Avatar
The Standard One
Ya if you want it lower from this point, I would adjust the spring perch.
Old Jan 29, 2004
Jap-Euro Fusion
I don't see how that'll help
Looky
Its an inverted monotube so the adjuster is on the bottom. As you go lower, the bottom bracket threads up the shock body and at some point the damper adjustment **** will poke out. It gets in the way. Moving the spring perch is just going to change the preload on the spring, it won't alter the ride height in anyway.
Old Jan 29, 2004
VNlilMAN's Avatar
The Standard One
Why wouldnt it? It would work like a conventional coilover setup.
Lets take an extreme example, lower the perch all the way down to the 3rd lock nut. This will cause the spring to sit freely. It'll probably have like a 1" gap between the top of the spring and the mount. This will cause it to lower 1". Isnt this how coilovers like tein work? You lower the perch and it lowers the car...
I mean if the perch was all the way at the bottom and there was still a preload than yet this wouldnt work BUT i'm almost sure the spring isnt that long to maintain a preload that far.
Old Jan 29, 2004
Jap-Euro Fusion
Where you see the perch in the photo, the spring is still unloaded, JICs come pre set for a 1.5" drop from the factory, so move the bottom bracket up 1" from there, you're looking at a relatively large gap remaining. That's also gonna dump the vast majority of the suspension load on the shock, which can't possibly good for it. They're rebuildable, but I think its something like $800 to get the shocks redone... so unless you're rich and can get the shocks redone often, I don't see this is a wise thing. They're racing coilovers, they're not designed to be slammed, they're intended to keep the car under control... if you unload them, it should make for an amusing ride.
Old Jan 29, 2004
VNlilMAN's Avatar
The Standard One
Ya most people who get JICs are for performance and probably wouldnt slam their cars but i'm just saying if you wanted to that is an option. It's not the best thing for the shocks but I dont think its horrible for it either. Most coilovers are designed this way and are fine even up to 2.5" like that. Since you do have the 3rd locknut you obviously wouldnt take the preload off it that much but probably 1" max so i dont think it would do much damage to them. I guess i'm trying to say its not ideal but it is an option
Old Jan 29, 2004
nightkids1's Avatar
Initial D!!!!
how much are those jic's anyways??? and are those ajustable shocks
Old Jan 29, 2004
VNlilMAN's Avatar
The Standard One
JICs are adjustable in so many ways... they run around $1,600
Old Jan 30, 2004
Jap-Euro Fusion
Unless you've got a real good hookup, you'll be paying more like $1750-$1850. And yes... just about everything is adjustable.
Old Jan 30, 2004
usafstud's Avatar
u can use the full 3" drop by removing the adjustment **** on the front shock
u do it by using a plier and turn the **** and and the washer together
the adjustment **** is basically a allen wrench that turns a small nut kind of thing under the **** that pushes a valve up and down
how do i know, i serviced my own
sorry about the wrong wording if i have done so
Old Jan 30, 2004
usafstud's Avatar
klj
Old Jan 30, 2004
JDMCIVIC's Avatar
JDM WHORE!!!
JDMCIVIC will become famous soon enough
how much did you get yours for?
Old Jan 30, 2004
Jap-Euro Fusion
Originally posted by usafstud
damn, 1750-1850 is way more than what i paid
Yeah, its way more than probably the 5 or so of us on here who have them paid... but I'm saying... if you take the $1980 retail and hack that down a little bit for a store price... thats what you end up with.
Old Jan 31, 2004
dragin's Avatar
piked mine up for 1500
GolNat
Nov 27, 2018 03:32 PM
wingsfan19
Oct 1, 2015 03:45 AM
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
EM_WON
Jul 22, 2015 06:49 PM
