skunk2 coilovers
Old Jan 19, 2004
Danger's Avatar
Danger is an unknown quantity at this point
skunk2 coilovers
i just got a set of skunk2 racing coilovers for my 02 coupe... anyone install coilvover on theirs? can anyone comment on skunk2's products if you have them on your car(suspension)? thanks
Old Jan 20, 2004
VNlilMAN's Avatar
The Standard One
Why are you researching on a product AFTER buying it? Shouldnt you do this before?
Atleast you are before your installing it tho.
My opinion on ANY sleeved coilover is they are crap. If you search/browse this forum you'll find out most people with blown struts had some type of sleeved coilover. If your going to use stock struts I recommend staying with lowering springs. If you must go with coilovers, get full coils or atleast some aftermarket shocks.
Old Jan 20, 2004
clownprince's Avatar
Ricerus Maximus
I have the Dropzone sleeved coilovers on my ride right now and they are awesome, very comparable to GC's. I can take corners like never before and the car absolutely rips the corners up, however, hit the slightest bump and the car bounces like hell. If you are even thinking of putting those on your car, prepare to drive slowly and carefully, even more than normal. Also be prepared to be shaken to death. I wouldn't put them on until you get some Koni's. That's the only thing that's going to make them ride decent. I'm taking my coilovers off and replacing them with Neuspeed Race springs, still not the best ride quality but better than the coilovers. I'm only doing that because since I had some unexpected bills I can't afford the Hayame's or the Konis that I want/need. That and I got a good deal on them. Of course if you want to put them on your car go ahead, just be prepared for a bumpy ride,
Old Jan 20, 2004
Danger's Avatar
alright thanks. and you recc. koni shocks or struts?
Old Jan 20, 2004
hondaciv01's Avatar
hondaciv01 is an unknown quantity at this point
i got the skunk2 coilovers, and they are nice, easy to adjust, the ride can get alittle bumpy, but not so much when you have it raised to a reasonable height, just don't keep it absurdly low for extended periods of time and it will be good.
Old Jan 20, 2004
Danger's Avatar
hey thanks, and what do u usually ride along the streets at? how low u got em? and what else have u done to the suspension.........
Old Jan 21, 2004
hondaciv01's Avatar
i just ordered some koni's, so the ride will be alittle better. goin on the freeway they are great, but when you hit a pothole or something you really feel it. plus i drive on detroit streets which are some of the worst in this country. before i had my car slammed way low, but i raised it up for the winter, and the ride gets better when you have it higher. be careful when you have it real low though cause the car can bottom out easily and you can mess up your front bumper. since they are so easy to adjust, i will lower it in the summer for probably a week then raise it to reasonable height again....my car handles great though, i move through corners sooooo quick, its great
the install is easy too, do it yourself and save $200. just now what you are doing before you get started......i didn't know what i was doing when i started, and unscrewed a bolt in the engine bay that wasn't meant to be uscrewed until the end, and it literally took me days to get the bolt back into position........if you do it right, should only take a few hours
Old Jan 21, 2004
Danger's Avatar
thanks, ya me and some friends are gonna do it, the diy shouldnt be too bad, and ill check out soem other links for some directions to use as a guide. i have a couple imports geniuses on my side for installation and advice, cheers
Old Jan 21, 2004
FattyMcJ's Avatar
Addicted to the Twisties!
Don't forget to post PICS!!!
Old Jan 22, 2004
Danger's Avatar
ya i plan to post pics of the car in the spring, i live in cleveland and im a jr in highschool, so im still busy. want to wait untill the cars lowered with the wheels back on.
GolNat
Nov 27, 2018 03:32 PM
Dave Brabant
20
Oct 6, 2015 12:44 AM
wingsfan19
Oct 1, 2015 03:45 AM
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
