skunk2 coilover installation problem
Old Jan 13, 2004
ricergribbs's Avatar
ricergribbs is an unknown quantity at this point
ok so i think i mightve madea dumb mistake. i bought some skunk2 sleeved coilovers, and i finished installing the front ones, and have moved onto the back. for some reason the rear springs are much harder to fit. they seem very tall for the space that is allowed for them and i was just wondering, where do the taller springs go, the front or the rear?
Old Jan 13, 2004
VNlilMAN's Avatar
The Standard One
i'm almost sure they go up front. i KNOW the longer threaded body goes up front so it would only make sense that the longer springs go up front as well. Try getting a second opinion tho, would hate for you to take apart your suspension only to be wrong again.
Old Jan 13, 2004
actually the taller threaded sleeves go in the back. i just checked teh instructions and it does say to put them in the rear, besides they dont fit around the front struts but they do fit around the rear ones.
Old Jan 13, 2004
DizWikedCivic's Avatar
smaller on the front and longer on the rear
also make sure to use the 0 ring
Old Jan 13, 2004
ok cool thanks. also, now that ive cleared up that i am doing it right, i am having trouble putting the back springs on. the top strut tower perch doesnt go all the way to the shock so i cant put the nut on. i tried using a spring compressor but that just bends the springs sideways, i tried using 2 spring compressors and i cant fit the spring on the strut. any ideas on how i could do this?
Old Jan 15, 2004
hondaciv01's Avatar
hondaciv01 is an unknown quantity at this point
the way i did it was i just held the whole suspension set up in the back up and got the bolt in at the bottom. just push the shock up alittle bit, it shouldn't need to be pushed up much at all, and but the bolts in. thats how i did the rears of my skunk2 install.
Tedverseti
Apr 23, 2020 01:45 PM
Youshoe
May 22, 2015 09:36 PM
Flatlander
Nov 16, 2001 05:38 PM
SneakerPimp
Nov 5, 2001 10:49 PM
SneakerPimp
Nov 3, 2001 10:57 AM
