Clunking sound.... need help
Old Dec 30, 2003
mndthegap1's Avatar
okay im not sure if this is normal or not so i figured ild ask.
i just got Ground Control coilovers and Koni yellows installed.
well i love the drive and how it feels now really nice.
my question is... when i hit a good size bump in the road i
hear a clunking noise (sp) is this normal or is something wrong ?
i just got it installed last night .
thanks in advance ...
Old Dec 30, 2003
VNlilMAN's Avatar
The Standard One
is it more like a thud? or more of a rattle?
rattle, eh try using some spring isolators or cable wrap. basically you just want to seperate any metal from hitting another metal.
if its a thud, your bottoming out and need to stiffen the konis and/or raise the car up a tad
Old Dec 30, 2003
mndthegap1's Avatar
it sounds more like a thud then rattle.
the drop is lower now, i put stock rims back on for winter and i can barley get 2 fingers in the gap so maybe its just that im bottoming out ?
ill check the konis.
VNlilMAN thanks for the info.
Old Dec 30, 2003
TOOLOWCIVIC's Avatar
I have the same setup and I hear a popping noise only from the drivers side. Its been like that for a while. Dont know what that is
Old Dec 31, 2003
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
i hear a grinding sound from my right rear when pressure is applied to that side when i turn. but the ride quality is still good, nor does it bounce when this happens. wonder whats wrong with it?
Injen
Old Dec 31, 2003
blackbullet's Avatar
The Legend
When I had ground control coilovers, I had the same problem. It went away though after a while.
Marco83
Oct 13, 2018 10:13 PM
Matt T
Idle Issues
Sep 24, 2015 04:53 AM
Josh 1973
Sep 7, 2015 10:10 AM
alwaysloyal360
Jul 29, 2015 02:26 PM
06Si_Girl
Jul 12, 2015 12:08 PM
