Tokicos In February 04
Old Jan 6, 2004
  #31
CapYoda's Avatar
Escaped Convict
Originally posted by JCiv03
^^^ lol, btw, capyoda, when's your new shipment of bushings comming in?
PM'ed you
back in on 1/20/04 but I'll be out of the country till 1/28/04 so yeah
Old Jan 6, 2004
  #32
Zzyzx's Avatar
Autocross Junky
The real queistion is will they out perform the Koni yellows, meanig are they adjustible and what range are they adjustible (harder or softer then the konis)???
Old Jan 6, 2004
  #33
lberry's Avatar
lberry is an unknown quantity at this point
The Illumina shocks are 5 position adjustable......I'm sure they will be adjustable in the same manner...but better than Konis....I donno! But if they come with the full kit and not just inserts.
Tokico is a good company and I think they will be WAY better than stock. They have been in the business of manufacturing shock absorbers and brake hydraulics for over 50 years. Plus you will not have to cut the strut housing.
Between the two I think it is a matter of preference. Just my .02
Old Jan 6, 2004
  #34
Jodster's Avatar
Post Whore General
I've got a set of Tokico struts new in the box sitting on my bedroom floor.
But they are for a 92 hatchback. Sorry.
Old Jan 8, 2004
  #35
O1Coupe's Avatar
O1Coupe is an unknown quantity at this point
Don't forget Tokico are the OEM suppliers for a lot of cars.. I know the well-handling Mazdaspeed Protege use Tokico shocks.. same with Mazdaspeed Miata.
Old Jan 9, 2004
  #36
slystad810's Avatar
Oh man I can't wait
Old Jan 11, 2004
  #37
streetglower's Avatar
If they do come out, I bet the price will start at over $500.
Old Jan 11, 2004
  #38
Tojo's Avatar
=) Im Bi-Sexual <3
Tojo is an unknown quantity at this point
i hate it when im highh..
Old Jan 11, 2004
  #39
gil_vtec's Avatar
gil_vtec is an unknown quantity at this point
Finally, cant wait till they come out I need shocks really bad so hope its soon....
Old Jan 25, 2004
  #40
slystad810's Avatar
Soooo.... It's almost Febuary... Any word?
Old Jan 26, 2004
  #41
7gen03's Avatar
7gen03 is an unknown quantity at this point
curious myself anyword
Old Jan 26, 2004
  #42
chicohonda02's Avatar
Since 2002 Baby!
its hopeless.
Old Jan 26, 2004
  #43
I dont think they will ever come out.
Old Jan 27, 2004
  #44
JCiv03's Avatar
ah, it's still january...
Old Feb 1, 2004
  #45
slystad810's Avatar
OK, now it's February...
Old Feb 2, 2004
  #46
clownprince's Avatar
Ricerus Maximus
and yet still no word.....
Old Feb 2, 2004
  #47
Wisper's Avatar
Wisper is an unknown quantity at this point
So are these Tokicos supposed to be better than Teins? Please explain or PM me.
Old Feb 2, 2004
  #48
robbclark1's Avatar
Retired suspension supermod.
Teins are true coilovers. Tokico's are shocks. There should be no comparision.
Old Feb 2, 2004
  #49
Zzyzx's Avatar
Autocross Junky
Depends on the valving, and what you are looking for in a shock.
My take on the whole subject....
Tokicos are Street perfromance shocks, and will probably work well with just about any spring (I dont konw about ride height)
Konis Are More tuned for High performance and Race applications, so they will have higher valving then the Tokicos, equaling better performance but probably a slightly rougher ride.
any coilover replacement (Spring and shock) is probably tuned to work together, or at least the spring rate that is pared with the shock is with in the shocks specs. so it could be assumed that a full replacement would if nothing else Last longer becasus the spring isnt over powering the shock.
However, it is entirly possible to have a Shock and spring set up (Non replacement) to perform as well if not better then a Full replacement coilover, you just need to pick the right spring and have the shock valved to work with it (Koni will Revalve their Yellow shocks). Its my understanding that Koni Yellows as they come from the factory are good till about 500-550 Lbs/in, and a Revalved to the max Koni can hold up to 700 LBS/In. I dont know what Tokicos are designed to handle, nor do I know if Tokico will revalved the Illuminas.
Old Feb 2, 2004
  #50
Civictuner04's Avatar
Civictuner04 is an unknown quantity at this point
I dont know what everyones problem is. I hav konis. They ride great and they arent too hard to install as long as u hav an experienced mechanic do it for u. U hav to deal with what u got.
Old Feb 2, 2004
  #51
well it is only feb 2, so give it a month, then bitch about it.
Old Feb 3, 2004
  #52
SimplePinoy's Avatar
SimplePinoy is an unknown quantity at this point
How will these work with lowered cars? will this be a simple replacement or wills mods have to be done?
Old Feb 3, 2004
  #53
dacivic's Avatar
dacivic is an unknown quantity at this point
Should be full replacement of the shocks. You still need the springs
Old Feb 3, 2004
  #54
JCiv03's Avatar
aiy! it says it'll be released SPRING 04 on their website... hope it's earlier than that!
Old Feb 3, 2004
  #55
flotsamm's Avatar
I read that KYB or Tokico(I forget which one) is only good for about a 1.5" drop. Anything more and you either void the warranty risk the chance of the shock failing. Whereas Koni's are better valved to handled a lower drop and also higher spring rates.
Old Feb 4, 2004
  #56
FattyMcJ's Avatar
Addicted to the Twisties!
Hmmm....
Old Feb 6, 2004
  #57
sKwiD's Avatar
I Queef > You
sKwiD is on a distinguished road
Well, I've also been waiting for them for like 1.5 years, but lets hope that this time its for real. Many times people have called and reported that this and that came out of the horse's mouth, but the shocks never come : (
Old Feb 6, 2004
  #58
lberry's Avatar
Well guys I give up....Those bastards at Tokico are now saying April 04.
Sorry for posting a useless thread.
I am going to save up money and get JIC Magic or Teins.
Old Feb 9, 2004
  #59
AZ2K1Civic's Avatar
FYI if anyone still cares
Tokico- California
1-310-534-3300
Michigan
1-313-336-5310
Old Feb 9, 2004
  #60
I guess, for now, we are stuck with konis and KYB
