rsx suspension swap
Search and Learn
The Standard One
yes its possible. I'm not 100% sure but i believe you need rsx tie rods and shave 1mm off the rear bracket. you also might have to drill the holes slightly bigger...
EP3 fits with no modification needed so if u just want the shocks and such go that root for five lug uhhh yeh i guess it would be easier to get the rsx since its more availible
Its a celebration bitches!
rear control arms from a ep will fit a em, i have the rear disc brakes, search befor you ask questions....
if you are keeping 4 lug just get the ep dampers... they fit with no modifications....
its only been done like 100 times, so i think it should work...
