Tanabe Sustec underbrace - who finally has one installed on their car?
Old Dec 6, 2003
opto_isolator's Avatar
Currently I have a neuspeed X-Brace. It does definitely work, but I am pissed off at their shitty design. The damn thing does not scrape on the ground, but hits the exhaust down pipe a lot, especially now that I just installed a magnaflow. So much so that I took it off, which sucks because I can tell it was working when cornering.
So anyways, I would really like to see a photo of this thing installed on someones car. I have seen pictures of it in other threads, but I want to see how much it really clears the exhaust (if any). I'd be willing to upgrade to this from my X-Brace if it fixes the damn exhaust rattling.
Anyone?
Old Dec 6, 2003
jdmb16ahatch's Avatar
jdmb16ahatch is an unknown quantity at this point
i have it no pics and i know grey has it and has pics up on the site it sits kinda low to the ground ive only scraped once leaving a very steep sloped parking lot it gets 2 thumbsup from me....
Old Dec 6, 2003
robbclark1's Avatar
Retired suspension supermod.
did you change your cat and your downpipe? I have no problem with mine with the DC TCS. If you plan on doing Autox, neither are legal in STS/STX...
Old Dec 6, 2003
ok, I read grey's DIY - it looks cool, but he says he still gets a little rattling on the exhaust.
I tried shimming the X-Brace with 1.5" washers, 1/4" in fact. It was working for a bit, until I had the exhaust welded (think it came down a little after he welded it).
I ordered some bolts from an Accord and S2000 (14MM flange bolts, just longer ones - I had to use OEM bolts because they are 10.9 grade. Its almost impossible to find 14MM 10.9 grade fine thread flange bolts, I've tried). The ones I ordered are 107MM in length for the front (vs 98MM) and 125MM for the rear (vs 115MM). So they should help. I'm going to try shimming 1/2" when I get the longer bolts, I think that will cure the problem up. It was rubbing so bad you can see the metal on the X-Brace.
I like the sustec, but if it still will cause rubbing than there's no point to upgrade to it......
I'll try and take a few photos of this if I can get it to work.
In the mean time, does anyone know of anything I can maybe wrap the X-Brace with, some sort of rubber or anything that can withstand the heat of the exhaust? Might be another alternative......
Old Dec 6, 2003
Sorry Rob, to answer your question - yes, I changed the downpipe (I have an LX). I had to use the piece that came with the magnaflow. I plan on hacking it up when I get my turbo eventually so I can weld a high flow cat in there somewhere. The 2.25" piping sure is larger in diameter compared to the stock!
Old Dec 9, 2003
cdmx's Avatar
I get no ratteling!! but ive scrapped the metal a lil bit at the ends where the bolts are...but the brace is still unscratched....right now i have horrible alignment and the brace is allowing me to drive much much better.
Old Dec 9, 2003
cdmx's Avatar
Try a thick rubberband....but you see that stuff in the engine bay covering the rubber fuel line? its like foam...that stuff works really good...its keeping my intake unscratched.
Old Dec 10, 2003
Grey's Avatar
DIY King
I don't get any rattle. I didn't say that I do, did I? Click the link in my sig for the link to the DIY.
Old Dec 10, 2003
DogstyleEX's Avatar
DogstyleEX is an unknown quantity at this point
i have it.. no noise at all.. i think i have to upgrade my rear sway bar again though.. it almost feels as if the back end can't keep up with the front now..i've hit the bar a few times too.. nothing like bad, just dumb stuff like if i was driving over a lump of snow in the middle of the road, i hear a "doonnggg"
Old Dec 10, 2003
Roy's Avatar
Roy
Roy is an unknown quantity at this point
dogstyleEx, which rear sway bar do you have now?
Old Dec 10, 2003
DogstyleEX's Avatar
i have the 19mm one... i'm thinking about getting the progress front and rear kit with the built in crossmember support....
Old Jan 22, 2004
usafstud's Avatar
sorry for posting on a old tread
so is the tanabe lower/higher/same height to the ground cause i don't want scraping on a low car
also, is it made for the RSX model?
Old Jan 22, 2004
Deamon32's Avatar
Deamon32 is an unknown quantity at this point
Hey i was planning on getting the x bar, and i have a full magnaflow catback installed, if it really does hit the exhaust, wouldnt it be easier to just position the exhaust piping higher... I have never seen pics of the xbar installed, so i dont know if its possible, can anyone give me an answer?
Old Jan 22, 2004
dragin's Avatar
dragin will become famous soon enoughdragin will become famous soon enough
i have the xbrace and dc tcs, no rattle at all
Old Jan 22, 2004
Grey's Avatar
DIY King
Click on the link in my sig to get to the DIY. There's plenty of pics there, including one of the Tanabe Sustec Underbrace installed.
Old Jan 22, 2004
usafstud's Avatar
does it get in the way of oil change?
Tedverseti
Apr 23, 2020 01:45 PM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
tylerginevan
Apr 27, 2015 12:29 PM
Ramen
Canada West
Nov 5, 2001 06:07 PM
ImmortalEX
Oct 31, 2001 10:00 PM
