NEED HELP LIKE ASAP Spring Problems
Old Nov 21, 2003
vicracer's Avatar
vicracer is an unknown quantity at this point
I had my stock spring put back on but and they make a popping noise everytime i turn or just turn the steering wheel i need to know are they on properly or not. Do they lock in place or what. I had a buddy do it for me so i am not sure they are on right
Old Nov 22, 2003
Vinh's Avatar
did you put those caps on?
Old Nov 22, 2003
civicvtec1ps's Avatar
Search and Learn
What caps???
Seems like Springs arent seated correctly. You might have to reinstall spring again.
Use white lithium grease for uppermounts.Just in case.Even though . I recommend doing it
make sure you bolted tight all bolts.
Front nuts and bolts that hold shock assembly to brake assembly(2 on each side):
116ft lbs. (includes oem replacement bolts)
Front end links:
29ft lbs
Front bolts that hold the bracket and bushings on front sway bar:
29ft lbs
Front nut that secures tie rod to shock assembly:
32ft lbs
Front and rear shock tower nut in center (on top of shock)
33ft lbs
Front three shock tower nuts (on top of shock around center bolt)
33ft lbs
Front brake hose and wheel sensor harness bracket bolts:
10mm one: 7.2ft lbs
12mm one: 16ft lbs
Rear bolts to rear upper arm or camber kit (all three):
43ft lbs
Rear nuts on end links:
top: 28ft lbs
bottom: 29ft lbs
Rear bolt that holds brackets and bushings on rear sway:
16ft lbs
Rear bolt that holds bottom of rear shock:
45ft lbs
Rear two shock tower nuts:
43ft lbs
Old Nov 22, 2003
Vinh's Avatar
ummm....the strut caps
reqy
Jun 1, 2015 07:05 AM
vtec_concept
May 24, 2015 10:27 AM
cruisers10
May 12, 2015 10:46 PM
oneheadlight
Apr 29, 2015 11:30 PM
Flatlander
Nov 16, 2001 05:38 PM
