Hard Banging noise with coilovers!!!
Old Nov 15, 2003
JDQuikCivic's Avatar
JDQuikCivic is an unknown quantity at this point
Just got my r1's installed with my stock shocks. Every little bump on the road I get this loud bang on the front driver side. I also noticed my driver side is lower than the passenger side. I know that if I raise it up again the sleeve won't move. But then I'm jacked up again. Any body have this problem before? Just want to eliminate as much of that bang as possible. Thanks for any info guys......
Old Nov 15, 2003
civicvtec1ps's Avatar
Search and Learn
First of all, bad choice with r1 sleeved coilovers. You cant really do anything about loud noice . since you have stock struts. That sound wont go away. Save up and replace struts or buy fullcoilovers Do you have any noise when you turn your steering wheel in slow speed? If so this is what you can do.
Some people are having problems with the dong sound coming from when turning the suspension. I believe that this is what is causing it, and will help if you do what is in the picture below. I used white lithium grease for mine.Even though we did not use any grease, I recommend doing it just in case.This pic was taken from Hondamans how to and I just added the arrows and such.
got it from ephatch. that should help.
and make sure you bolted tight all bolts.
Front nuts and bolts that hold shock assembly to brake assembly(2 on each side):
116ft lbs. (includes oem replacement bolts)
Front end links:
29ft lbs
Front bolts that hold the bracket and bushings on front sway bar:
29ft lbs
Front nut that secures tie rod to shock assembly:
32ft lbs
Front and rear shock tower nut in center (on top of shock)
33ft lbs
Front three shock tower nuts (on top of shock around center bolt)
33ft lbs
Front brake hose and wheel sensor harness bracket bolts:
10mm one: 7.2ft lbs
12mm one: 16ft lbs
Rear bolts to rear upper arm or camber kit (all three):
43ft lbs
Rear nuts on end links:
top: 28ft lbs
bottom: 29ft lbs
Rear bolt that holds brackets and bushings on rear sway:
16ft lbs
Rear bolt that holds bottom of rear shock:
45ft lbs
Rear two shock tower nuts:
43ft lbs
Old Nov 16, 2003
I can't see the picture....I pm'ed you thanks for replying. Is there any way that I can weld the sleeve to the strut to keep it from moving? Any thing like spacers to soft tension springs to keep the sleeve from moving?
Old Nov 18, 2003
What about rubber spacers custom cut?
Old Nov 18, 2003
djmota's Avatar
switch back to stock and put those POS r1's in the trash where they belong. Save up for something NOT cheap and install that. Those coilovers will blow out your stock struts very fast.
Old Nov 19, 2003
I'm getting koni's used in one month. I just want to ease the banging noise as much as possible.
Old Nov 19, 2003
TriptronicCIVIC's Avatar
TriptronicCIVIC is an unknown quantity at this point
ditch those coils....
plus i had that problem with all my cheap sleeeved coils... you got them installed improperly... you have to remove a piece but i forgot which one hehehe
anywyas i paid like 1500 Canadian installing and buying drop zones and ground controls... ALL JUNK! save your hassle and buy true coils... I have KW right now and they're pretty good.
Misfit2613
Jul 30, 2015 09:49 AM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
fvckbg
Jul 7, 2015 07:08 PM
