strut tower bar or rsx rear sway
Old Nov 17, 2003
playaz0429's Avatar
playaz0429 is an unknown quantity at this point
ok, i understand that the front strut bar reduces chasis flex, and the rsx sway reduces understeer. i have searched and found that, but my ? is, with what product will i notice more of an improvement for cornering? Moreover, which should i do first, the rear sway or the front strut tower bar?
thanks all.
Old Nov 18, 2003
playaz0429's Avatar
wow no replies or nothng, i thought at least i would get the search flame
Old Nov 18, 2003
Zzyzx's Avatar
Autocross Junky
Rear anti Roll bar. much better Balance.
though I can say that you will feel an improvement with the Front strut tower bar. the sway bar will help handling much more.
Old Nov 18, 2003
half_n_half17's Avatar
half_n_half17 is an unknown quantity at this point
I just put an e-bay front upper bar on and i can totally feel the difference. The turn in is much crisper and there is less understeer... there is still a bit of understeer, but for 15 bucks ya can't beat it.
Old Nov 18, 2003
djmota's Avatar
the rear sway bar will be 10 times more noticeable than the front strut bar.
Old Nov 18, 2003
Zzyzx's Avatar
Autocross Junky
think of it this way:
the front strtut bar will make the front end more stiff allowing the suspension to work better, but it keeps the same roll couple distribution (Handling balance), because spring rates/roll rates were not changed.
the Rear anti-roll bar will adjust the Roll couple distribution becasue it adds to the rear roll resistance..
SO..... The strut bar will make the car "Feel" more solid, where the antiroll bar will actually change the handling of the car.
(this is if you can only get one, other wise I say get both! as well as any other chassis reinforcement you can afford)
Old Nov 18, 2003
playaz0429's Avatar
sweet answer
Old Nov 19, 2003
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
Neuspeed strut tower bar first
Old Nov 19, 2003
playaz0429's Avatar
neuspeed is sweet, but am gonna hold off and do the rsx sway 1st, its a little more in the budget at this moment.
Old Nov 20, 2003
dacivic's Avatar
dacivic is an unknown quantity at this point
If you get the rsx sway bar first your rear will be too stiff. That is no good, so you must get a front strut bar to balance. I would do the front strut first then the rsx sway bar.
Old Nov 20, 2003
Zzyzx's Avatar
Autocross Junky
?????? thats not right. A strut bar is a chassis reinforcement. it lowers the amount of flex at the front of the car. the Rear anti-roll bar is part of the suspension, that changes the roll rate at the rear of the car. These things do two different jobs. one strengthins the chassis the other changes the handling balance.
So, THe car will not be unbalanced by getting the 19mm anti-roll bar. what will happen is that the font will feel as washy as normal but the car will understeer less.
fatih717171
Jul 25, 2016 06:22 PM
JohnnyBxo
Nov 12, 2015 03:04 PM
mistermenphis22
Jul 13, 2015 04:43 PM
OptimisticWay
Jul 10, 2015 04:31 PM
SpecialRequest
Jul 7, 2015 07:52 PM
