question for koni yellow users
Old Nov 12, 2003
sffree's Avatar
sffree is an unknown quantity at this point
I have an 02 coupe with H&R springs and koni yellows. Is there supposed to be a creaking noise that comes from the rear struts' polyurethane bushings?
Old Nov 13, 2003
Vinh's Avatar
sway bar kiddo
Old Nov 13, 2003
Vinh's Avatar
oh wait...u got an 02 Lx?
hmm...that doesn't come with sway barz
unless u got aftermarket
Old Nov 13, 2003
sffree's Avatar
exactly.. so I repeat my question... koni yellow users.. are your rear koni yellow struts creaking when going on uneven roads and dips and driveways and such??? I was told that it was because of the struts' polyurethane bushing....
Old Nov 13, 2003
ElmoZaPimp's Avatar
ElmoZaPimp is an unknown quantity at this point
I've had my Koni's a couple of months now and have experianced no noises like that. Try some white lithium grease near the pivot points that might help.
Old Nov 13, 2003
djmota's Avatar
sffree ...you still got that same creak huh ? My yellows where quiet for a year then one started to creak. It turned out to be. the lower bushing on the strut. It got pushed and a little to one side and a bit crooked in the hole. I took it out used a press with the proper sized socket (so I could just push on the bushing) to get it centered and straight again. When I reinstalled the strut. I put a bit of grease on the sides of the bushing and on the bolt just to make sure nothing binds up. It hasn't squeeked since/
Old Nov 13, 2003
sffree's Avatar
damn... the thing is that every time I want to do something, I have to take it to my mechanic. I am 100%, absolutely, without a doubt, clueless on how to do the work myself---and I don't even have a setup to do the work even if I knew how (i.e. no jack stands or anything that would allow me a closer inspection)...I just got these new rear strut replacements from Koni the other day (apparently they've had several issues with it not fitting right onto the stock honda control arm. Anyways, the fit is MUCH better, but the creaking persists. ARGH
Old Nov 13, 2003
sffree's Avatar
oh. hey .. one more thing. Would it be completely wrong to just swap out the koni yellow rear bolt ons with the regular factory McPherson ones? would that not work right on a lowered car with springs? I wish I could upload an audio file to everyone could here this BS. anyhow.. thanks for the info ya'll
Old Nov 13, 2003
djmota's Avatar
the factory struts will blow out sooner or later. Have you tried taking it to a different shop? Maybe a different set of eyes and ears might help.
Old Nov 13, 2003
sffree's Avatar
did that. the installer of these recent replacement fixes was a different dude than the other ones who were supposedly 'Koni Distributors'.. go figure. Would the lube suggestion be a temp fix? is it something I can do without disassemblying the who suspension?
Old Nov 13, 2003
djmota's Avatar
to truly lube the lower bushing you would have to take off that lower bolt... you would need a jack and stands to do the job
Old Nov 14, 2003
CivicHX01's Avatar
no creaking here... yet...
Old Nov 14, 2003
HYPR DRV's Avatar
Since 1977
HYPR DRV will become famous soon enough
I'm having my Konis installed tomorrow. Man, I really hope I don't have any of the problems peeps up in here have been having. *knocking on wood*
Old Nov 14, 2003
Roy's Avatar
Roy
Roy is an unknown quantity at this point
some springs tend to creak. it's normal if it does. nothing bad with them.
Old Nov 14, 2003
sffree's Avatar
really? do you know specifically for H&Rs? Now that you mention that... I didn't have this problem when I had my original set of springs on... But I'd be surprised because the old springs were crappy 'Matrix' brand.... Is there anything I can do if it IS the spring? Though, if it was the spring, I'd be having the problem in the front too? no?
Old Nov 14, 2003
sexcivic2k1's Avatar
u gotta put some grease on that bushing for the bottom of the strut, mine did it, its nothing a little grease won't help
Old Nov 16, 2003
Profoxcg's Avatar
Profoxcg is an unknown quantity at this point
my rear is also squeaking over bumpy roads, can someone post a picture of what need to be fixed? please?
I am running stock struts in the front, I want to order the koni adjustables but I hears they are pretty hard to install in the front. I want to know if anyone knows a place that can do such job in my area (florida miami / ft. lauderdale)
thanks !
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Tedverseti
Apr 23, 2020 01:45 PM
viper775
Dec 9, 2001 10:52 PM
SpoonSportsd17a
Nov 24, 2001 12:43 PM
