struts II
Old Oct 28, 2003
civic-king's Avatar
civic-king is an unknown quantity at this point
struts II
hey!!
my thread got locked.
i'm sorry i didn't make myself clear.....
i DID a search in the FAQ, i know about the ONE strut that fits. that FAQ is OLD!!!!!!
i figure that there were more out there than the ONE strut that fits. (actually 2)
i wanted to know if the RSX struts fit the civic, or if there were any others.
like i said, i FOUND others, but they are inconsistant years of fitability. (is that a word?)
i was asking what fits? can i buy struts for a 95 and have them fit? like i said, i found them that fit 92-04, and i wanted to know if the assembly and mounting was the same throughout the years?
(moderator)i've been searching all morning, so please don't lock my thread untill i get some answers for my questions, please.
thank you for your help.
~the king
Old Oct 28, 2003
robbclark1's Avatar
Retired suspension supermod.
I told you what ones fit.....if you want factory struts, just get new civic ones, not much difference between ours and the RSX or Si ones. They should fit but no need for them. No other years shocks will fit. If it doesn't say for the 7thgen civic then they don't fit. The only ones you can get safely right now are the Konis! i know of no one that has the GR-2's. The FAQ is not old, it was just updated. No one makes shocks for our car yet. Tokico and KYB are working on it! I am glad you searched, but there aren't many shocks out yet. Plain and simple. If you want performance then you have to get konis, if you want factory then just get new honda ones, if you want better than oem but no performance then get the Gr-2's. That is it. I will leave this open for a little while, but there really ins't more information on this subject that we haven't said already.
Old Oct 28, 2003
civic-king's Avatar
thanks.
i've found a few for the RSX as well.
thanks for leaving it open for a few.....i might post some good prices....
.....so you think the ones for 92-04 are bogus, eh?
humm.....searching time
Old Oct 28, 2003
robbclark1's Avatar
anything that says 94-01 or 94-02 are full of crap. You shouldn't find any more for the RSX than the Koni's. they share the same chassis so everything is the same for them and the Si. You might find some Moton ones but those are $1400 a corner.
Old Oct 28, 2003
civic-king's Avatar
RSX=SI
RSX=EX LX DX?
EX LX DX= SI?
Old Oct 28, 2003
robbclark1's Avatar
no Acura RSX, Honda civic Si, and honda civic all share the same chassis. the hatchback is the Si and has more horsepower.
Old Oct 28, 2003
civic-king's Avatar
so
RSX=SI=EX/LX/DX
SWEET.....
Old Oct 28, 2003
robbclark1's Avatar
in terms of chassis, yes. There are some small differences like tie rod bolts, front sway bars, and other things but most suspension parts can be used on all 3.
Old Oct 28, 2003
civicvtec1ps's Avatar
Search and Learn
Originally posted by civic-king
so
RSX=SI=EX/LX/DX
SWEET.....
uuh yea , just suspension chasis. whats so good about that.
Old Oct 28, 2003
civic-king's Avatar
i don't know. it makes shopping easer.
Old Oct 28, 2003
Zzyzx's Avatar
Autocross Junky
Basically if it fits an RSX it probably will fit a civic.... there are some parts that cant be used, but that is because of how the engine is mounted inthe RSX and Si vs the EX and others.. (Like the Front anti-roll bar on the RSX/Si)
For shocks, Konis are good. the Yellows are good to about 450-500 LB/in springs, and Koni will revalve the shocks for higher rates if needed. From what I've read about them, even the Valved to the max Koni Yellow isnt much good past 700 LB/in. Many of the top drivers in SCCA Solo 2 events run Koni Yellows.
Old Oct 28, 2003
VNlilMAN's Avatar
The Standard One
not really cause most products that are out for their cars are out for ours. most cause there are those few that arent out for ours...
and ya they still require slight mods like new tie rod ends. making the holes bigger. shaving things here and there...
reason why the 94-01 are bs... the 7thgens use a different suspension setup that those so they are much different. we use mcpherson struts opposed to double wishbone back then.
Old Oct 28, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
To use RSX shocks you need new tie rod ends.
It appears that EP3 struts can be used straight up....
The Mugen Sport Kit ($1000, springs and shocks, 0 adjustment)
Spoon Fixed Dampers ($950, no adjustment)
Spoon Adjustables ($2750, Height and damper adjustable, no springs)
and the Mugen/Moton ($4200, height and damper adjustable with remote reservoirs)
are presumably usable if you got the cash.
Old Oct 29, 2003
civic-king's Avatar
....uhhhhmmm...i pretty poor.
i'll probibly go with the koni yellows. i don't need anything that extreme.(1000-4000 per corner or set? it doesn't matter though)
where do you think is the best deal?
Old Oct 29, 2003
Search and Learn
www.tornactive.com for koni yellow. use discount code.(dont ask what it is. search )
Old Oct 29, 2003
dj02's Avatar
what's the drop on the mugen sports?
Old Oct 29, 2003
VNlilMAN's Avatar
The Standard One
http://www.7thgencivic.com/forums/sh...ighlight=mugen
he said 1.4"
Old Oct 29, 2003
Search and Learn
about 1.4
207 lb/in Front and 413 lb/in rear.
Tedverseti
Apr 23, 2020 01:45 PM
SammySC
121
Apr 7, 2017 07:43 PM
skeener51
Oct 1, 2015 05:56 PM
ken4444
Sep 30, 2015 07:37 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
