Does this setup fit our Civics?
Old Oct 17, 2003
BlackIce's Avatar
BlackIce is an unknown quantity at this point
I have an 01 Civic EX, just curious if this will fit our vics?
Ebay Link
Old Oct 17, 2003
djmota's Avatar
front probably not rear yes.... but the stock si rear does not look that much bigger than stock ex.
Old Oct 17, 2003
robbclark1's Avatar
Retired suspension supermod.
i am not sure of the stock sizes for the Si. I would have to agree that the front doesn't look like it will fit. The rear will definitely fit, but doens't look that much bigger. your stock front bar is 1" or 25.4mm. Pretty big and may even be bigger than the Si bar.
Old Oct 17, 2003
civicvtec1ps's Avatar
Search and Learn
si rear sway bar is bigger than ex. which is 15mm. and yes it will fit
si stock front sway bar is 25mm
Old Oct 17, 2003
BlackIce's Avatar
So will both 19mm or a 21mm fit our car then? I assume that the 21mm would be better. Let me know, thanks! For the rear sway bar I mean...
Old Oct 17, 2003
Search and Learn
yes 19mm(rsx stock rear sway bar) 22mm(ctr) will fit on your car. it will increase oversteer.
progress . neuspeed rear sway bars also are 22mm but has integrated low tie bar. i would just go with 19mm rear sway bar. can be found pretty cheap on www.clubrsx.com for used one.
Tedverseti
Apr 23, 2020 01:45 PM
GH04si
Apr 15, 2015 08:13 PM
aus10
Apr 13, 2015 09:26 PM
