front end
Old Oct 6, 2003
dragin's Avatar
dragin will become famous soon enoughdragin will become famous soon enough
front end
ok i have the neuspeed x brace, and upper tower bar in front.
what else is avail to sure up (tighten, stiffen) the front of an 03 lx? and were to get it?
Old Oct 6, 2003
Vinh's Avatar
Neuspeed Poly something Bushings for front sway bar
Old Oct 7, 2003
robbclark1's Avatar
Retired suspension supermod.
a rear sway bar. Because it is a FWD car the tend to understeer. In order to correct that you should make the car want to oversteer. A 19mm+ sway bar should help.
Old Oct 7, 2003
Zzyzx's Avatar
Autocross Junky
I assume you want to tighten up the front end because it keeps understeering right? (Where the steering wheel is turned but you keep going straight) robbclark has it right, you need to change the Roll resistance at the back of the car. so either get a larger Rear anti-roll bar, or get springs that have a Higher rate for the rear end.
Old Oct 7, 2003
Sickboy's Avatar
Sickboy will become famous soon enoughSickboy will become famous soon enough
The 03's have 15mm/12mm swaybars I believe, as opposed to the 25mm/13mm combo of the 01-02s. So, would switching only his rear sway bar to a 19mm really be a good idea for a street setup? Would 15mm/19mm create too much oversteer for street?
Old Oct 7, 2003
Zzyzx's Avatar
Autocross Junky
Most likely not, when Honda went to the smaller swaybars, they probably compinsated it by increacing the overall spring rate. so I think the 19mm would be fine.
Old Oct 7, 2003
Sickboy's Avatar
Do you know of anyone with a 15/19 setup Zzyzx? I've got a stock 03' 15/12 and I can't decide which I should upgrade to. Progress with new endlinks is a bit pricey for me at the moment. Should I wait or get used 25mm and 19mm bars? The 03' has extreme body roll by the way.
Old Oct 7, 2003
Zzyzx's Avatar
Autocross Junky
hmm, mad Body roll huh?
maybe honda was just trying to make the ride smoother.... interesting.
I have an 01 EX, and with the 19mm bar it rarely wants to oversteer.
For a cheep test run, you could get the 19mm bar, and if you found it oversteerd to much go find a used 25mm bar.
Thats what I would do.
Old Oct 7, 2003
dragin's Avatar
i was looking for a front sway bar, any other ties i dont now about for the front end....
the reason is the back of the car is very stiff and i need to balance it out a bit... i was thinkin of a sway bar, but not sure if itll do the trick.
in the rear i have the neuspeed tie/sway combo, neuspeed springs, and cusco upper tie bar....
so im just lookin to sure up the front end a lil bit more.
Old Oct 8, 2003
Zzyzx's Avatar
Autocross Junky
Rear end beign stiff like how? How does the car handle now? does it understeer or oversteer?
You may not need the front end "Sured up". infact if you add a larger front Sway bar it may caues more understeer. as far as structural reinforcement, sure get them, but they have little to no effect on Understeer or oversteer. they just allow the suspension to do its job better.
Old Oct 8, 2003
dragin's Avatar
hard to explain in an unconfusing manor..... has nothing to do with under/over steer
Old Oct 9, 2003
Sickboy's Avatar
dragin i have an 03' EX and mine reminds me of my mom's old minivan in the twisties. You said you upgraded the rear to a 22 neuspeed sway so you're running with a 15mm/22mm sway combo correct? Most people here seem to like 27/22 and 25/19 combos so I think you should look into a bigger front sway like you mentioned. PM me with your results please because I'm looking into upgrading my sways soon.
Old Oct 10, 2003
dragin's Avatar
i will when i figure out what step is next lol..... like i said the car rips thro the twisties..... but the front just needs to be a bit stiffer to balance out the back.. as of right now the only options i gave found is a spoon front lower tie bar(no idea were i can find it tho), and a bigger sway bar...
Old Oct 10, 2003
Sickboy's Avatar
If you haven't already, read Zzyzx's Suspension Tuning 101. Great info. You have all the tie bars so it really sounds like you're in need of a bigger front sway bar. Check your front tire pressures also you'd be amazed what 6psi will do.
edspyhill09
Jun 12, 2016 02:45 PM
Lopes101
Jun 7, 2015 08:04 PM
chuffsy
May 15, 2015 12:50 PM
pheaton
May 4, 2015 08:26 PM
GH04si
Apr 15, 2015 08:13 PM
