spring install question???
Old Sep 21, 2003
curlyb8675's Avatar
curlyb8675 is an unknown quantity at this point
Recieved my goldline springs the other day for my coupe 1.75 all around. And installed them today. But when i did it i noticed the front springs to be considerably shorter than stock but my rear springs were practically the same size. Installed both and my front is nice and low with about a one finger gap space, but my rear looks not to be lowered at all.??????? Did i miss something. Ive tried searching no luck thought..all help/coments would be greatly appreciated. thanks
Old Sep 22, 2003
velocity's Avatar
velocity is an unknown quantity at this point
IVE GOT THE SAME PROBLEM BUT MINE LOOKS SOMEWHAT DROPPED JUST NOT ENOUGH IN THE REAR
Old Sep 22, 2003
Mr.Modify's Avatar
Ummm well when ya lowered it did ya have your E brake on? cause when mine got lowered when they put the springs on and then dropped it off the Jacks it still looked Stock but then after i moved the car back and then forward again it dropped to about a 1finger gap ....my **** looks hella tight now!!
Old Sep 22, 2003
Jodster's Avatar
Post Whore General
The back did not drop all the way down cause you do not have the weight back there like you do in the front. Take the car out for a drive and take a couple of sharp turns. Then go home and look at the back, that should settle the springs down. But remember, everytime you jack up the back of the car you will have to resettle the back springs.
Old Sep 22, 2003
curlyb8675's Avatar
thanks alot guys...you were right all i had to do was take the brake off and drive it and presto..all good and low. Now all thats left is to get it aligned.
MN-02-CivicEx
Jun 25, 2015 08:32 PM
Nalmonte
Suspension
Jun 9, 2015 07:08 PM
reqy
Jun 1, 2015 07:05 AM
oneheadlight
Apr 29, 2015 11:30 PM
wsking77
Aug 29, 2001 05:34 PM
