known issues with the 02 civic and koni yellow strut replacements?
Old Sep 19, 2003
sffree's Avatar
sffree is an unknown quantity at this point
I lowered my 02 civic lx cpe and put in koni yellow struts... the rear suspension creaks really bad now... and the koni installer said the it was a known issue btwn koni and honda... anyone experience this problem?
Old Sep 19, 2003
Mr.Modify's Avatar
they make koni yellow struts? do you mean the shocks? if so i never heard of that i was actually thinking about getting those to!!
Old Sep 20, 2003
Amplify's Avatar
Amplify is an unknown quantity at this point
What do you mean by "creaks really bad"???
Sure, my car makes suspension noises too, but nothing I would classify as really loud creaking. *shrugs*
Old Sep 21, 2003
Ronin's Avatar
Ronin is an unknown quantity at this point
--> moved to suspension
Old Sep 21, 2003
01EXtc's Avatar
01EXtc is an unknown quantity at this point
u mean koni sport replacements
Old Sep 21, 2003
sffree's Avatar
I dunno how else to describe it... Anyone else have Koni yellows installed on an 02 civic coupe? It's only the rear suspension too... this is frustrating. I figger if it's a normal noise that comes with 'lowering' that it would be all over....
Old Sep 22, 2003
pdxbiker's Avatar
pdxbiker is an unknown quantity at this point
I have it on my 01 civic ex coupe for we'll over 1 year with out any noise or problems.
Old Sep 22, 2003
djmota's Avatar
do you have a rear camber kit?
there have been loud squeeking problems with those
Old Sep 22, 2003
sffree's Avatar
yes. rear and front camber kit... But if the camber kit is typically an essential part when you lower the car than I don't know why it would do that.
Old Sep 22, 2003
cefird21's Avatar
cefird21 is an unknown quantity at this point
I have Koni yellows on my 02 civic lx coupe, and have no problems with the back, the front sounds like it hits hard sometimes, but over-all, I am satisfied with them.
Old Sep 22, 2003
cefird21's Avatar
Also, I only have front camber kit right now, and still have no problems out of the rear end.
Old Sep 22, 2003
Narc's Avatar
Narc is an unknown quantity at this point
How much did you guys pay for your Koni yellows?
Did you install yourself?
I ask cuz its my next mod.
Thx in advance.
Old Sep 22, 2003
Amplify's Avatar
http://www.tornactive.com
Old Sep 23, 2003
vvii's Avatar
vvii is an unknown quantity at this point
i have yellow koni stocks installed, it was great, and they are fine, without making any noise...
I pay $1500 Canadian dollars, tax in, with yellow koni shocks, neuspeed race spring and installation. I think the koni is about $1000 CAD, and it was a good deal from my point of view
Old Sep 23, 2003
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
I got the koni's from Group Buy Center for 500 shipped. I put them in myself and it's pretty much a pain in the ***. The rears are no problem, but the fronts need modification. You have to cut and gut the front strut housing and internals. You will need some time, but WELL worth the effort. Cornering is amazing with these.
Old Sep 23, 2003
djmota's Avatar
what happens with the rear camber kit is alot of people tighten the inside bolt with the rear of the car in the air. This is wrong, once you put you car down the bushing inside gets loaded and twisted, ( not drunk and hammered ) thus it brakes loose on the inside and moves when your rear suspension moves. What you are hearing is a rubber bushing moving when it should not. You are supposed to preload the suspension by putting a jack under the drum and getting it to the ride hieght, then tighten.
Old Sep 25, 2003
sffree's Avatar
so does that mean I will have to replace the bushing to get rid of the noise? or can it be saved? how much am I looking at if you know? thanks
Old Sep 25, 2003
djmota's Avatar
there is no replacing the bushing but you can try loosening that bolt and then thightening i up the proper way and see if that makes a difference.
Old Sep 25, 2003
sffree's Avatar
I did see somewhere an official honda recall about the 02 civic and problems with the rear trailing arm bushing. Is this the bushing you're referring to? are you sure it can't be replaced? hmmm.. thanks for all the info tho..
Old Sep 25, 2003
djmota's Avatar
the bushing i am talking about is on the rear upper arm. this arm is the piece that is replaced with a camber kit. So not oem honda but whatever brand camber kit you have.
Old Sep 27, 2003
sffree's Avatar
if re-doing the rear camber install doesn't work, what are my options? I still have the original arm I think... what about installing a diff brand? Is there a brand that works/fits well with the 02 civic?
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
GH04si
Apr 15, 2015 08:13 PM
thesushiboy
Apr 12, 2015 02:54 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
JeffSpeed21
Nov 4, 2001 10:32 PM
