EP3 Owners help Coilover question
Old Aug 17, 2003
XxJDMCivicxX's Avatar
Post EP3 Owners help Coilover question
My friend is looking into buying new full coilovers for his ep3, he is considering tein, kw, and the new mugen coils that came out. Anyone know if the mugen ones are full coilovers not much info on them. Any other coils that are better? Which would be the best choice, Price doesn't really matter.
Old Aug 17, 2003
civicvtec1ps's Avatar
Search and Learn
go with KW.
mugen one is just springs and shocks. non height adjustable. only lowers 1.4 all around. thumbs up for kw from me. price is good too 1150 ( i think ). shipped from tornactive right now
i wish i had money to buy for my ep3
Old Aug 18, 2003
Zzyzx's Avatar
Autocross Junky
Totally depends on what he wants from his suspension. that will determin what set up is best for him.
Old Aug 19, 2003
Some auto-x every now and then but he just wants a great ride quality with about little to no gap appereance. Just something that rides great and can handle some hard turns everynow and then .
Old Aug 19, 2003
Zzyzx's Avatar
Autocross Junky
Then just about any suspension will work. I'd go with what ever is cheepist. Probably Tein SS, or KW's type II.
Old Aug 19, 2003
Search and Learn
kw 2, upgrade sway bar to rsx sway bar(19mm). ep3 has 15mm rear sway bar. new bushings.rear upper strut bar, upper strut bar.
Old Aug 19, 2003
SlammedBlueEM2's Avatar
All Eyes On Z
Jay-Eye-See-Magic.
Old Sep 22, 2003
EternalVTEC's Avatar
EternalVTEC is an unknown quantity at this point
Will the rsx rear sway bar fit the EP3?
Old Sep 22, 2003
Search and Learn
yes
Old Sep 23, 2003
dj02's Avatar
Originally posted by SlammedBlueEM2
Jay-Eye-See-Magic.
best full coil over IMO.
Old Sep 23, 2003
Zzyzx's Avatar
Autocross Junky
Depends entirly on your intended application. So, while the JIC suspension is a good suspension, it is not nessisaily the best. Like for me, for instance. to me the Jic is not an option because of my needs. I autocross and the Jic suspension dosn't have enough options for me to tune my suspension to the fullest (The current Version availible for our cars is only single adjustible). So personally the KW type III is the better choice, because it is adjustible in both Bump and Rebound, allowing me to tune my suspension to meet my needs. Most people would never Know how to or want to put the effort in to tuning the suspension to this level, so the KW type III's would clearly not be the best choice for them.
See, The best suspension for you depends entirly on your intended application.
Old Sep 23, 2003
dj02's Avatar
true on that but i also due auto-x, and drag, and have auto-x with a car on jic's 2k2 vic, and it was just awsome! on my 4dr i got stock shocks with ebiach sports and its not to shabby... rsx rear sway, nuespeed upperstrut brace. but it is totaly up to the person that is getting them. but when i do go full coil over i will be useing jic's, like i said just think there the best IMO.
Old Sep 23, 2003
Snort2001's Avatar
Snort2001 is an unknown quantity at this point
from what i've experienced with the JICs, they are truly amazing. i think they are the best full coilover IMO too. but zzyzx is right, it totally depends on your intended application
Old Sep 23, 2003
All Eyes On Z
Tein SS' do not fill the entire wheel gap when dropped at it's lowest.
Old Sep 23, 2003
All Eyes On Z
Old Sep 25, 2004
Ocelaris's Avatar
Ocelaris is an unknown quantity at this point
Now I don't wanna talk trash about KW, because I have them, and for a year they've been great, but I just talked to one guy who's rear shock blew, and I know another guy who's front blew after about a year... I just put on my KW Upper bearing mounts (which look great, and feel great) and my front passenger's side is making a huge "whoooshing" sound going over bumps... How can you tell if a damper is blown? Maybe something's loose... gotta get in and make sure everything is tight in there... but it makes me worry. But they've been nice so far, actually they feel great, I'm dreading if my frount passenger's shock is blow, I'll have to go back to stock
How long are coilovers supposed to last given daily driving conditions? I mean, shouldn't they last like 5-10 years???
Old Sep 25, 2004
robbclark1's Avatar
Retired suspension supermod.
What do the upper mounts look like? Does the top of the shock just slide into the mount? Make sure everything is tight. You can tell it is blown if there is oil leaking out of it. It should not be blown if it was made right. KW says they are supposed to last, then they should last, not give out. You should be able to race on them and still be fine.
Old Sep 26, 2004
Ocelaris's Avatar
The upper bearing mount replaces the stock upper bearing mount... basically it just sits on top of the spring, and the damper goes through it. Probably something is loose, I didn't see any oil per se... as I've heard other people describe blown shocks as... But I had greased the stock upper bearing mount, and had so much grease and crud in there, would have no idea whether anything leaked out or not... plus, where would the oil be coming from, just where the damper goes into the strut right? wouldn't that just leak out onto the ground and be gone by the time you check?
And are dampers supposed to "rebound" i.e. if I push it in, it should come back out on it's own right? I mean, I basically have to take the strut apart again, so if I have it out, any way to check if it's doing it's dampening job? Nice to see you again Robb ^^
Misfit2613
Jul 30, 2015 09:49 AM
NoobyKid
Jul 13, 2015 07:53 AM
Kyles24
Jul 12, 2015 09:15 PM
ZILLA
Jul 10, 2015 06:05 AM
