b&g just installed!
Old Aug 9, 2003
bublik's Avatar
Truehonda.com
bublik is an unknown quantity at this point
b&g just installed!
I just got my b&g's installed and the ride is nice. The cornering is not as good as I thought it would be, I mean it is good, but not that hard. I know I cant adjust them, but what is a good thing to do to make the cornering better? Is this right for them to be kind of soft around turns. As well, the rear seems to be not as hard as the front.
Old Aug 9, 2003
civicvtec1ps's Avatar
Search and Learn
upgrade sway bar, front strut bar. rear upper strut bar.
Old Aug 10, 2003
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
Welcome to the B&G Family.
As far as improving cornering, I'd recommend the following in the order of importance.
1. RSX 19mm rear sway bar (or bigger)
2. Neuspeed Front upper strut bar
3. Poly bushings on F & R sway bars
4. tie bars all around.
Old Aug 10, 2003
bublik's Avatar
Truehonda.com
Thanx, already got some cheap strut bar for the front, I will put it on again and see how things to with it. Did it really make a difference?
Old Aug 10, 2003
jwsisme's Avatar
jwsisme is an unknown quantity at this point
I'd recommend these items in this order:
1) Neuspeed Front upper strut bar (you'll notice the difference right away)
2) Neuspeed X-brace -(increased stability at all speeds, more BMW-like)
You'll be amazed at the transformation and your really just fixing the front-end flex problem our cars have.
I haven't done the struts\springs yet, but I have a lot more performance then stock.
Old Aug 10, 2003
opto_isolator's Avatar
No pops, creaks, squeaks? Good if you don't since a lot of others seem to have had those problems.....
Old Aug 10, 2003
Weaponx12o's Avatar
welcome to the B+G family
sorry, but you cannot adjust the damper settings. the B+G's have the S3 system (speed sensitive suspension). it automatically adjusts your damper settings to road conditions and your speed. so if you're driving slow, it will soften the dampers, but if you drive fast, the dampers will stiffen. so if you take a corner slowly, the cornering wont be as stiff. but if you take that same corner at a higher speed, it will be stiffer.
what these guys said is right though, upgrade the front and rear sway bars. and get strut bars all around. get the neuspeed upper front strut bar, neuspeed x-brace (lower front). pretty much any upper rear strut bar (spoon preferably, but the obx works fine too). and a good lower rear tie bar
Old Aug 10, 2003
Weaponx12o's Avatar
btw, i havent really had any problems with my B+G's squeeking, only when they get wet though. the only thing that squeeks for me is my camber kit.
Old Aug 11, 2003
ncwcivic's Avatar
ncwcivic is an unknown quantity at this point
i squeak in rear from camber (i will fix soon) and front because of 2002 top mount (need to change to 01)
i have clank when hit big bumps but that is it
i love mine
slammed to the ground
Old Aug 11, 2003
jwsisme's Avatar
Reading over the thread again...
I would put on that "cheap strut bar" you say you have, and if you can notice the big difference I felt, just use it.
I bought the Neuspeed because I have more trust in their products, which I think decreases my chance of problems down the line.
But if yours works and wears well, then you found a better value then I did.
There is no way I'll drive without my front upper strut bar again, and come to think of it...I'd really hate to live without my X-Brace.
You might get more performance outta the rear sway, but I dunno I haven't got mine yet.
The flex was just driving me mad, so it was more like fixing problems then adding performance, and fixing is my priority.....anywayz, the end result is that it did both and the car is much more sporty.
So you got the B&G's... now just put on the finishing touches.
Old Aug 11, 2003
bublik's Avatar
Truehonda.com
thanx man, to anyone who wants a good ride and good handeling (similar to a bmw) get these, germans never screwed up suspensions
Old Aug 11, 2003
jwsisme's Avatar
Good point about the Germans...
So you really like the ride quality?
How's the freeway ride, road noise, and the bigger bumps?
BTW, does anyone know the spring rates on the B&Gs?
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
