busted suspension? or just alignment? *update*
Old Jul 29, 2003
wonderz's Avatar
wonderz is on a distinguished road
Question busted suspension? or just alignment? *update*
---update---
so I jacked up my car and took the wheel off the car to see if i can figure out what's broken. from what i can see, the left Y shape arm (lower control arm?) has a tear in it and disconnected from the front sway bar. (there is a litttle joint that connects the sway bar and the control arm, and it got disconnected on the control arm's side) So i tried to pry the lower control arm back to normal and alignment the wheel a bit. The steering is almost back to normal, althought there is still a small pull. the noise from the back seems to disappeared after i put the wheels back on and i can't see what's wrong in the rear.
so here is my questions:
1. how much does the left lower control arm cost?
2. can i replace it myself or do i have to take it to the shop?
TIA
---first post---
ok, today the craziest thing happened. when i am driving to school and i exited a freeway ramp, the floor layers on the ramp had different levels and my car just jumped up (like came out of a pothole). and since the exit ramp is a turn, my car just lost traction and my car first hit one side, and then bounced back to the other, until finally i can regain control...the only good thing that came out of it is i didn't hit any car and my car has no visible body damage i know of.
now to the bad news...my steering wheel is off-centered...i can see one of my front rims doesn't point straight...steering is noticibly(sp?) worst, won't return center immediately after i pull to one side...noise came from rear of the car (the rear suspension, i am guesssing)...not to mention my rims got scratched up at the lip...
so i want to know
1. if anyone know if anything is messed up? I can't see any fluid coming out or anything.
2. Can I just take my car to an alignment shop and they can fix it back to normal?
3. Should I get a camber kit for easier alignment even thought my car is not lowered?
4. anyone good aftermarket parts I can replace the oem ones if I needed to replace anything? (ie lower control arm)
i know the post is kind of long, but please help
thx
Old Jul 29, 2003
CivicHX01's Avatar
1. the stock suspension should last the lifetime of the car, if you think there is something wrong with it, take it to the dealer and get it replaced by warranty
2. yes take it to an alignment shop, it should make your car back to normal
3. you don't need a camber kit if your car is stock height
4. there is no aftermarket lower control arm that i know of (although i think gray wants to make custom ones to widen the track in the rear)
Old Jul 29, 2003
horatio's Avatar
horatio is an unknown quantity at this point
steering wheel is off-centered.......
sounds like a tie bar problem
Can u just take my car to an alignment shop and they can fix it back to normal?
i think so.
Should u get a camber kit for easier alignment even thought yourcar is not lowered?
nope.
Old Jul 29, 2003
CivicHX01's Avatar
oh, and you might want to get your wheels re-balanced and to check and see if maybe your rim got bent...
Old Jul 29, 2003
civicvtec1ps's Avatar
Search and Learn
check tire pressure, get rebalanced, realignment.
Old Jul 29, 2003
wonderz's Avatar
how much do u guys think these repair/service will run me?
1. rebalance rims
2. realignment for my car
thx
Old Jul 29, 2003
CivicHX01's Avatar
alignment is usually around $35
rebalancing is usually around $9 per tire
call tire shops around your area... the price varies...
Old Jul 29, 2003
CivicHX01's Avatar
and you should do this as soon as possible because your tires will wear out if you drive around with messed up toe (unaligned)
Old Jul 29, 2003
5PEED EX's Avatar
5PEED EX is an unknown quantity at this point
I got somewhat suspension problem, yesterday I installed Dropzone lowering springs (2inch all around) and now when I'm making turns or backing up and making turns my front suspension is making clanking noise. Do I just need to let springs adjust to rest of suspension or is something fucced up ? The sound is really anoying. You cant hear it when going straight or when slightly turning. Just hard turns. Anybody know whats causing this ?
Old Jul 29, 2003
horatio's Avatar
i've heard of that happening before, but i dont have drop zone so idunno, if you search im sure youll find a post on it.
Old Jul 29, 2003
Search and Learn
its normal
Old Jul 29, 2003
wonderz's Avatar
only $35 bucks for complete 4 wheel alignment? I did a search, and ppl responded in the thread about $80-$100 for normal alignment, and $300 for messed up ones...
Old Jul 29, 2003
Search and Learn
35 is VERY cheap
most likely around 75-100..
Old Jul 29, 2003
pheaton's Avatar
A descendant of 2k1civic.com
Weird that it even happened though. . Unless you were hauling some serious ***.
Old Jul 29, 2003
SeThisBlaze's Avatar
SeThisBlaze is an unknown quantity at this point
its 45 for a alignment job around my way
Old Jul 29, 2003
horatio's Avatar
i think i paid 60-70 dollars for alignment
Old Jul 29, 2003
wonderz's Avatar
*updated*
Old Jul 29, 2003
5PEED EX's Avatar
Originally posted by civicvtec1ps
its normal
Does it go away or what ?
Old Jul 30, 2003
GanariGuY's Avatar
GanariGuY is an unknown quantity at this point
damn u guess pay mad cheap for alighnment
Tedverseti
Sep 29, 2015 05:41 PM
Wariogamer
Sep 29, 2015 09:49 AM
TheRiddicles
Sep 21, 2015 01:28 AM
czarlun
Sep 14, 2015 08:16 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
