***SPORTLine Lowering Question***
Old Jul 23, 2003
liveola's Avatar
liveola is an unknown quantity at this point
A few days ago I got my car lowered, 2002 Civic LX 2door. I got the Eibach Sportline Lowering springs. Anyways, the people installed them, but the car doesnt look too low...I thought sportline was the lowest drop with eibach. anyways, I asked the guy and he said give it 3-4 weeks, and the springs will compress and it will lower more. Is this true or was he just making that up? Also, they said I dont need a Camber kit for another 6 months, but when I went to get my alignment done the next day, the guy at goodyear said I need to get the camber kit now before he can do the alignment on my car. If anyone has this SPORTline lowering springs, did it get lower the coarse of a few weeks than it was when you got them put on? if anyone knows.
Thanks.
Old Jul 23, 2003
liveola's Avatar
yeah, appreciate that, im new to the forums on here. but thanks. and yeah how long does it usaully take to settle? and do I need to know anything about that camber kit? get it now? get it later? any help yall can give me.
Peace!
Old Jul 23, 2003
liveola's Avatar
so at first when they put the springs in, it wasnt a 2 inch drop, but once it settled that side is now a 2 inch drop? my bad if im annoying ya, jus really tryna set this straight lol....dont wanan feel like i totally wasted my $$ when I coulda got like coil overs or something....
Old Jul 23, 2003
liveola's Avatar
preciate that.. maaan...you made my day lol, all I needed to know was some info from someone else who got it done too. Oh yeah, did you get the camber kit then? you recommend I get one? are these any good...
Skunk2 Front Camber Kit..
or
Sprint Camber Kit
Either one of them............and its only the front that needs it? or what?
Thanks.
Old Jul 23, 2003
liveola's Avatar
alright. sounds good. about to put in the order.
Thanks.
Old Jul 23, 2003
agungmeth's Avatar
agungmeth is an unknown quantity at this point
Hi,
What's he function of camber kit?
Old Jul 24, 2003
xtiszx's Avatar
Cracka
xtiszx is an unknown quantity at this point
corrects the "tilt" of the wheel,
like if its lowered it the top of the wheel is pointed inside the wheel well,
like this <kinda>
and camber allows you to adjust it so its stright
Old Jul 24, 2003
agungmeth's Avatar
Do we need to change our stock camber kit if whe lowered our car with lowering springs?
Old Jul 24, 2003
Mr.Modify's Avatar
I HEARD YOU SHOULD GET A CAMBER KIT IF YOU LOWER IT OVER 1.75"IN? IS THIS TRUE?
Old Jul 24, 2003
xtiszx's Avatar
Cracka
well the inside of the tire will wear ALOT faster then the rest of the tire, so ya i would, iv blown a tire on my car, just by putting on 17's, wasnt even lowered, the top was in a bit, and in about a year or so, drivin down the freeway, a chunk of rubber came off, so if you dont have the money at first, do it asap,
Old Jul 24, 2003
xtiszx's Avatar
Cracka
just putting on bigger rims can cause it to wear on the inside, its not as bad if you had it lowered, if you lower it any amount, put a camber kit on it
Old Jul 24, 2003
born2xLr8's Avatar
Wow...some good info guys I was looking into sportlines and 17's myself.
What's up with "cutting/clipping" springs? Is it when people want a lower drop then the springs provide?
Old Jul 24, 2003
xtiszx's Avatar
Cracka
its cutting the oem spring ( DO NOT DO THIS) its sooo bad for the car, but ya, cutting them is a poor mans way i guess
Old Jul 24, 2003
flotsamm's Avatar
Yeah dont cut or use spring compressors to lower your car. You risk the chance of the spring popping out since its shorter.
I have sportlines, it took a few weeks for my springs to settle another 1/4". I suggest that you wait a few weeks yourself and then take it in for an alignment. I only bought the rear SPC kit, the front didnt need it.
Old Jul 24, 2003
liveola's Avatar
appreciate all the replys....
Old Jul 25, 2003
xtiszx's Avatar
Cracka
np. pm me if u have more questions
GolNat
Nov 27, 2018 03:32 PM
skeener51
Oct 1, 2015 05:56 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
bhollie
Sep 22, 2015 11:08 PM
