anyone has JIC MAGIC coilovers?
Old Jul 21, 2003
usafstud's Avatar
Hey,
I'm looking for coilovers and my friend told me to check out JIC. How do these compare to Teins? I'm looking for KW's or JICs that are equavalent to or better then the Tein SS.
I'm looking for coilers to do track/autocross racing.
thanks
Old Jul 22, 2003
robbclark1's Avatar
Retired suspension supermod.
Both the Kw's and JICs are better than the Tein SS. The Tein flex would be equivalent to the JICs and better than the KWs. Yes there is a member here who has the JICs for an RSX.
Old Jul 22, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
The kit was actually for a CTR, but thats neither here nor there.
If you're going to autocross on them, I would make sure that the pillowballs are STS legal. It would suck to end up in SM or SP because of it.
There's a rule for ST that says something about the mounting being the factory location, etc..... and I don't know if Pillowballs are within that realm.
Here's the rule straight from the book:
"Any shock absorbers may be used, provided they attach to the original mounting points. The number of shock absorbers shall be the same as Stock. No shock absorber may be capable of adjustment while the car is in motion, unless fitted as orignal equipment. MacPherson strut equipped cars may substitute struts, and/or may use any insert. This does not allow unauthorized changes in suspension geometry or changes in attachment points (e.g., affecting the position of the lower ball joint or spindle). It is intended to allow the strut length changes needed to accommodate permitted modifications which affect ride height and suspension travel. "
Besides... if you've never done it before or haven't done it much... don't put a new suspension in yet. Drive on the stock one and force yourself to keep the car under control. You'll become a much better driver for it later on.
Old Jul 22, 2003
HondaLuver's Avatar
Its a celebration bitches!
since you can't adjust the stiffnes, i think they are talking about tein flex with EDFC.
Old Jul 22, 2003
HondaLuver's Avatar
while in motion
Old Jul 22, 2003
jedo's Avatar
jedo is an unknown quantity at this point
refer to this thread. it talks about tien, jic, and kw.
Old Jul 22, 2003
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Re: anyone has JIC MAGIC coilovers?
Originally posted by usafstud
Hey,
thanks
I have the JIC Magic FLT-A2's for the EP hatch on my 2001 ex and they fit and perform wonderfully. They retial for around 1900 but you can get them cheaper if you check around. You WILL NOT be dissappointed with JIC Magic they are IMO the best!
GolNat
Nov 27, 2018 03:32 PM
wingsfan19
Oct 1, 2015 03:45 AM
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
EM_WON
Jul 22, 2015 06:49 PM
