air ride
Old Jul 15, 2003
bublik's Avatar
Truehonda.com
bublik is an unknown quantity at this point
air ride
Is air ride tight around turns? How much do all the bags and stuff weigh?
Old Jul 15, 2003
Green Civic's Avatar
I dont have air ride, but I think its around 100 lbs with all the equitment. But Im not too sure.
Old Jul 15, 2003
robbclark1's Avatar
Retired suspension supermod.
http://www.7thgencivic.com/modules.p...Suspension+FAQ
Old Jul 15, 2003
HondaLuver's Avatar
Its a celebration bitches!
4 air cylinders, compressor, and tank(s), and rubber hoses... add that up then minus the stock suspention component that you will replace...
Old Jul 16, 2003
blackbullet's Avatar
The Legend
If you're into the performance side of suspension, I wouldn't get air ride. I have air ride and would never use it to take tight turns, etc... Air ride is more for show.
Old Jul 25, 2003
CIVICONBAGS's Avatar
CIVICONBAGS is an unknown quantity at this point
believe me if u have the setup done rite u could take turns faster than coils... im in the process of switching my setup to air tech's bolt on.. but wit cylinders and bags in front i could take corners faster than when i had performance springs on it... add the fact that u can drop a side and u could take turns at 80! you should see some of the **** i do wit my suspension =D
Old Jul 27, 2003
dragin's Avatar
dragin will become famous soon enoughdragin will become famous soon enough
what cylinders,valves, fittings, comps, line type & sizes r u runin??????????
i have been runnin air ride on cars and my truck or some time now....
Old Jul 27, 2003
TOOLOWCIVIC's Avatar
Air ride
Old Jul 28, 2003
Willy's Avatar
Willy is an unknown quantity at this point
hey too low what type of suspension, do you have on the back, what brand , where did you get them???? i have just bags on the front of mine ,just not low enough, should the back go lower than the front? thanks
Old Jul 29, 2003
dragin's Avatar
well civic on bagz?? dropin the side down hard when ur doin 80 through a turn? and other crazy stuff frequently?
im dyin to know cause thatll blow most 99.9% of sytems faster than hell and twist ur car.....
Old Jul 30, 2003
Hey ***** thats not my car. Thats 2low4us car. Hes got airstruts in front and just bags in back. Thats why the back is so low cus theres not struts back there. How do u just have bags up front??
Old Jul 30, 2003
Willy's Avatar
i have strut bags on the front of mine right now,and i was wondering if i got bags in the rear would it slam it.
Old Jul 30, 2003
If u look at the pic u can see that he hits the ground in back. Hes got bags in rear no shocks. The front is not gonna go any lower but the back will. U got any pics of ur ride.
Old Jul 31, 2003
Willy's Avatar
i can send them to your email. dont know how to put them on the site.
Old Jul 31, 2003
toolowcivic@yahoo.com
Old Aug 1, 2003
AltimaGuy03's Avatar
AltimaGuy03 is an unknown quantity at this point
i think air ride is cool but its pretty bouncy not sure how stiff it is around corners tho
Old Aug 2, 2003
It can be bouncy but I've been is cars that ride very smooth like a luxury car. It just depends on ur setup.
Old Aug 3, 2003
VNlilMAN's Avatar
The Standard One
ya it depends... some lincolns ride on air stock and those ride nice...
Old Aug 3, 2003
Willy's Avatar
i tried toolow but it says my file is to big, and i dont know how to convert it over, ill get my buddies digital in a few days.
Old Aug 5, 2003
civic01vtec's Avatar
If u are more go than show, then bags are not for you. They ride nice but u can't race around corners on them, too hard on the bags. I like nitrogen better, i think that it rides nicer than air, but that could be just me. Nitrogen is faster than air if u wanna bang switches. Also nitrogen won't expand and contract with the temperature conditions like air does.
Old Aug 5, 2003
The Legend
I tuck the front tire with mine. I had to cut the perch in the front though.
Old Aug 6, 2003
VNlilMAN's Avatar
The Standard One
you tuck? cut the perch? what does it sit on? what kit do you have?
Old Aug 6, 2003
The Legend
I have the EAI kit. I have air struts in the front. It comes with two plates that connect to the top and bottom of the air strut. There is still just enough room for the strut bag to sit on. But cutting the perch made a big difference. I also have 19's which I think helps out a little.
Old Aug 6, 2003
2low4u did the same thing. He cut the front perch off and now it sits a lil lower then it did before. I take a close up pic of the front this weekend. He didnt get the EAI kit but its very similar. Airstruts up front and bags in rear.
Old Aug 12, 2003
dragin... i run prototype strut bags in front and cylinders for the rear with 1/2" lines, fittings, and valves... 4 5 gal tanks .. 4 hardlined compressors... and i have no problem dropping a side to lean hard into a turn... recently f***ed up my strut but that's cause of a totally unrelated cause... drove over a pothole at around 80.. >=( f***in' cali highways...
Old Aug 12, 2003
Hey civiconbags how low can u go?? Do ur 4 compressors make a lot of noise or what. Got any pics of ur 4 compressors and tanks??
Old Aug 13, 2003
as of now i lay in the front and lay in the back... and yes the compressors can make quite a bit of noise but you get used to it.. i just blast the music over em... and you can find some old pics of my setup of 2 tanks and hardlined compressors in my members rides... the setup and the drop looks completely different right now... i just need some time to post pics
silentz
Jul 9, 2015 08:16 PM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
7thgensurvivor
Jul 5, 2015 12:17 PM
Causemo
Jul 4, 2015 07:11 AM
