Koni & Drop height problems
Old Jul 7, 2003
kFanghe's Avatar
kFanghe is an unknown quantity at this point
I don't know if anyone's experienced this, at least I couldn't find anyone. Anyways I installed a set of H&R springs with Koni yellows and the ride height increased . I had the H&R's installed on my stock shocks before and the ride height was lower, especially in the rear. BTW I have a sedan DX. I then installed a set of Neuspeed specific sedan springs on the koni's(has a lower drop in the back supposedly) and the rear was even higher (3-4 finger widths). Right now the car's about 2 fingers in the back and 1.5 in the front. Before Koni's it was like 1.5 front and 1 in the back. Somethings not right, anyone know??
Old Jul 8, 2003
brents1's Avatar
brents1 is an unknown quantity at this point
yeah, I hear konis will raise the height a little. Were your stock shocks blown when you had them on? Thay may be why they looked so low.
Old Jul 8, 2003
Zzyzx's Avatar
Autocross Junky
Its not unknown to have Gas shocks raise the ride height of a car. it just happens.
Old Jul 8, 2003
robbclark1's Avatar
Retired suspension supermod.
Stock shocks aren't made to be lowered and are quite soft on the civic. When you put a firmer shock on there, the ride height will be raised up.
Old Jul 8, 2003
VNlilMAN's Avatar
The Standard One
for the back, check the perch. there should be 2 places where you can put the perch. its possible you used the one at the top when you should have used the bottom one.
Old Jul 8, 2003
VRoomPSHeRt's Avatar
VRoomPSHeRt is an unknown quantity at this point
are the two perches the same strength? meaning can i use either one, and it wont hurt the shock or ne thing?
Old Jul 8, 2003
VNlilMAN's Avatar
The Standard One
ya you can use either one... they just made it for "height adjustability"
basically its a nice function for sedan owners(cause if you want coupe springs you can use the upper perch to raise the rear to compensate for the extra weight in the rear).
i'm guessing they put the perch on the upper one cause h&rs are for coupes only and when you got the neuspeeds, they just left it there instead of switching it to the upper one
Old Jul 8, 2003
so the konis will raise my car a little? both front and back?
Old Jul 8, 2003
sexcivic2k1's Avatar
wow, if it is true, that is good to know , i have neuspeed race, 2.25" f, 2.0" r.. and i wanted mine to be a little higher if i get a lip kit
Old Jul 10, 2003
CivicHX01's Avatar
it does raise it a bit... i left my ground controls on the same height setting and both the front and rear raised up... but its nice to have coilovers because i just lowered it back to the height i wanted...
also, since you just installed the konis they will need some time to settle too... drive it around about 20 miles and the height you'll see will be the permanent one...
Old Jul 16, 2003
kFanghe's Avatar
Yes, it's on the lowest perch and everything. And yes the springs have settled, but check this out. Notice the Koni perch is higher than the factory shock. Don't get it. I'm asking koni about this one. Anyone else with this problem??
Old Jul 16, 2003
kFanghe's Avatar
sorry about that, check the difference b/w the factory and the koni's perch heights
Old Jul 16, 2003
Yukonart's Avatar
Yukonart will become famous soon enough
That looks like it's on the higher perch.
This is where I HAD to set mine to keep my tires from compacting the fender lip during normal suspension travel. Had the ICE put in the trunk (phase 1) and it lowered the rear of the car a good inch. Then I installed the Konis and set them to the higher perch, and things were back to normal. . . perhaps a little higher. This is all because I thought it'd be a good idea to have over 150 lbs of custom work done back there.
Anyway, the Konis are MUCH more firm (especially on the firmest setting, duh) and my suspension travel is well within the specs of what I need it to be with the wider wheels and tires.
Adjustable perches = GOOD.
Rogelio Rey
May 24, 2015 08:30 PM
cukaracha
May 16, 2015 07:36 PM
crowtoo
May 11, 2015 06:50 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
JeffSpeed21
Nov 4, 2001 10:32 PM
