parking on a hill?
I'm thinking of moving to a new apartment. The only problem is that it's on a decent sized hill on a one-way street that goes downhill. I'm concerned about the long-term wear on the parking brake. Is this something that I should be worried about?
To a lesser extent I'm a little concerned about parallel parking on the left side (no parking on the right). So I'd be having to reverse back up the hill and park on the left. Seems totally backwards.
Any help?
Any help?
If you have a manual transmission and are parking downhill, put your car in reverse gear after you turn the ignition off. This will give you some insurance in case the parking brake goes out.
If you're parking uphill, place it in one of the forward gears (I usually use 2nd).
EDIT: My bad, I just read your sig (CVT transmission). Just make sure your parking brake is engaged nice and tight. Also try parking behind somebody else, in case your brakes go out you'll hit them instead of flying into someone's house.
The Man, Myth and Legend
From: Western Canada, where the beer is cold and the women are HOT!
Use the curb to your advantage. Park on the curb and turn your wheels towards it. Use the parking brake and you should be fine. If the parking brake does give out, the curb will help act as a back up, by keeping the car from rolling too far.
Civicforums Junkie
using the parking brake wont 'wear-out' the brakes at all...applying the parking brake will also keep the rear brakes adjusted...
you should apply the brake before shifting into park
nirvanaguy
25
Oct 26, 2017 07:26 PM
danace99
Oct 17, 2015 02:51 PM
Klame9420
Sep 18, 2015 12:37 PM
