wheel nuts
Old May 6, 2003
macrossranma's Avatar
macrossranma is an unknown quantity at this point
wheel nuts
should i get aftermarket wheel nuts for 17" rims or can i reuse stock nuts?
Old May 7, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
you cannot re-use the stock nuts. They're ball end nuts for steelies. Find out the taper in the new wheels and buy the matching lug nuts.
Old May 7, 2003
Blk4blk2K1's Avatar
Retired Super Mod and STILL Pimpin' Yo Mama
Blk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to behold
Thats not exactly true, I used my stock lugs with my 17" Konig's, worked fine. It was only temporary til I got my original lugs.
I would suggest getting aftermarket lugs, especially if you live in or travel to high crime areas, or even any level of crime for that matter. It's a matter of self-satisfaction.
Old May 7, 2003
Jap-Euro Fusion
If you use the ball nuts in a hole meant for conical taper nuts then you can damage the rim. its like trying to put a round peg in a triangular hole. It concentrates all the force on the ring where the ball end actually contacts the taper rather than the whole length of the taper. So you could make an impression in the rim from it, and they don't stay all that tight.
Old May 7, 2003
ok, thanks, but what if i have oem 2002 Si rims that comes stock, im in Canada, will the nuts that came stock(for the Si rims) be use on aftermarket 17" rims?
Old May 7, 2003
Jap-Euro Fusion
no.. they're made for the ball nuts. You should buy a set of nuts that will go with the new ones. What kind of rims are they??
Old May 7, 2003
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
just DONT get kyokugens... LONG story....... but it SUCKED
Old May 7, 2003
i got black racing proN1, ok, im getting new wheel nuts than, thanks
yeah, no kyokugens, i heard bad stuff about these nuts too
Old May 7, 2003
Zzyzx's Avatar
Autocross Junky
I've used kyokugens before, and the only time ive ever seen a problem with them is when people over torque them.
But if you do end up striping them they are a pain to get off.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
juror
Suspension DIY
Jul 30, 2019 03:28 AM
logsplitter1
Aug 9, 2015 09:32 AM
WaryDriver
Aug 8, 2015 05:08 PM
califcamper
Jul 21, 2015 10:34 PM
