Brembo Rotors on wrong direction?
Old May 3, 2003
CivicBR900EX's Avatar
Master
CivicBR900EX is an unknown quantity at this point
I am not sure what's making the noise. I tightened the bolts on the calibers tight, but it's got this slight grinding noise when the wheels rotate, and when I make a complete stop, it makes a noise too. I wonder if I put the rotors the right direction; check the slots and holes.
Old May 3, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
They're on right... make sure they're on straight, check the same for the calipers. Check to see the pads are properly seated and not rubbing. Double check the torque on the wheels, make sure they're not rubbing on the dust guard, etc.... start checking everything. If both the pads and rotors are new, they may just need breaking in, but that wouldn't explain the noise when the car is moving.... just when stopping.
Old May 3, 2003
Master
the car is new, got 1200 miles on it. However I didn't lube the brakes before I reassemble them. Do I need to lube them?
Old May 3, 2003
flotsamm's Avatar
I dont think any lube is required. Perhaps its just break in noise that will disappear after a few days?
Old May 3, 2003
civicvtec1ps's Avatar
Search and Learn
its on right direction. just let it be for couple days to see what happens.
by the way . where did you buy it? i want to get them myself
Old May 3, 2003
Master
I got them on Ebay for $98 a pair. This shop sells rotors only.
Old May 4, 2003
Master
Thanks guys, problem solved, I bled the brakes and no more noise!
Old May 5, 2003
Search and Learn
good to hear! i need to grab those myself now. no cash arrg,
any reviews? would you recommand ?
Old May 5, 2003
RoadRunner's Avatar
good deal !!
Old May 5, 2003
Master
I wrote a review, check out review section.
Old May 5, 2003
OHERC's Avatar
OHERC is an unknown quantity at this point
mine are opposite...
are you sure they are on right. I have drilled/slotted rotors, and they are opposite.. and installed at Kramer Tire
how do u post pictures
Old May 5, 2003
Master
I just checked many other cars with drilled/slotted rotors. I got them on right.
To post a pic, click on "post a reply" on the buttom there is a button you can browse through your harddrive for the pic you want to upload.
Old May 6, 2003
OHERC's Avatar
thanks
for the reply.. I guess I know what I'll be doing Friday. I did notice an increase in going w/these drilled/slotted rotors (even though they're on backwards!!) geez.. I'm beginning to not take my car to Kramer tire agian...
the image thing.. it looks for a website... not my hard drive[IMG]c:\rim.bmp[/IMG]
Old May 6, 2003
OHERC's Avatar
ahh...
I guess I know what I'll be doing Friday... won't be taking my car back to Kramer after this..
thanx for photo "how to" for dummies...
Old May 6, 2003
Master
I painted my caliper black....thought it probably wouldn't look too ricey, but i care barely see the calipers now...
cukaracha
30
Jul 26, 2015 12:01 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
General 7th Gen
Jul 9, 2015 10:17 PM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
671civicLX
Jul 4, 2015 04:02 PM
