Wider wheels & alignment
Old Apr 29, 2003
dma001's Avatar
dma001 is an unknown quantity at this point
Apologies in advance if this is a dumb question, but:
In reading some of the members' posts about wider rims, drops, camber kits, and so on, I've gotten a little confused: will adding wider wheels but NOT dropping my car throw off my alignment in any way? Is the camber, etc. affected by JUST adding wider wheels without any lowering?
Old Apr 29, 2003
CivicEnvy2001's Avatar
CivicEnvy2001 is an unknown quantity at this point
It shouldn't mess up your alignment, but when I got my rims put on, they checked my alignment and I needed it fixed. That just could be because my car had never had an alignment before.
Old Apr 29, 2003
Da2K1's Avatar
Da2K1 is an unknown quantity at this point
No, as long as you keep the original tire+ rim diameter (you can use the calculator on this site.
Old Apr 30, 2003
VNlilMAN's Avatar
The Standard One
nope, you can get wider/bigger wheels and the alignment will stay the same as before you put them on...
wheels dont effect alignment, n yes this includes camber
Old Apr 30, 2003
dma001's Avatar
Cool! Thanks, guys...
Old Apr 30, 2003
PunkingCivic's Avatar
I need TP for my bunghole
I would be best if you get a new wheel and tire set up to get the alignment done.
most places will do this if you get the set up from them.
This way from the start you are sure that the alignmet is correct and you jack a new set of rubber. It is a little insurance/assurance policy when getting new tires.
But do what you like.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
BryanM.
Aug 29, 2015 03:26 PM
jedi
Aug 3, 2015 04:26 PM
Dangerousjordan
Jul 28, 2015 08:24 AM
carid
Wheels and Tires
Jul 20, 2015 07:15 AM
