tire size
Old Apr 28, 2003
macrossranma's Avatar
macrossranma is an unknown quantity at this point
tire size
hi, im totally noob about tires, i got black racing 17" here is the spec 17×7.5J offset 45 HOLE 4 /P.C.D. 100, will 215/45/17 tires fit with this rim perfectly and fit on my civic?mine is lower with H&R sports, 1.3" lower, pls assist, thanks
Old Apr 28, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
With a 45 offset on a 7.5, I'd be worried about the inside edges rubbing during hard turning, but with the 7.5, you've kinda ruled out 205s. 215/45 will fit and shouldn't rub the fenders, but *might* rub the liners if you turn the wheel all the way, I'm not totally sure.
Old Apr 28, 2003
u meant the front wheel might rub if i do a full turn?, but all that bolt pattern and PCD will fit on a civic right?hows your es100? is it running good and what do u think of the threadwear of the tires?im considering this tire or the kuhmo 712
Old Apr 28, 2003
Jap-Euro Fusion
yes, 4x100 is right, 45 offset is ok, but if you turn the wheel all the way, the tires might rub, I'm not sure... my wheels are 37 offset, I have the opposite problem of the fenders rubbing. I would definately choose the AVS ES100s over 712s. Especially if you plan on beating them up. At autoX today I got into a discussion with a guy who has 712s and isn't at all happy with the grip or the durability when it comes to giving them a pounding. My Yoks held their own... I actually still have edges on them after 7 runs. They run through rain like it's nothing and the best thing is they're quiet. Tire Rack... $97.
Old Apr 28, 2003
umm, ok, the yokos that is, thanx for your input, its worth paying 200cad over the kuhmo since the yokos are better than kuhmo in every category, hope the yokos can last at least 2 summers since i dont even go to autoX
Theshwartz35
Jul 17, 2015 11:13 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
muttleytm
Jul 8, 2015 04:13 PM
BootyDo
Jul 7, 2015 06:06 AM
Causemo
Jul 5, 2015 06:42 AM
